Rough Idle where should I start
running around 900 to 1000 rpms in neutral . But once in a while a notice a shimmy when I am just sitting still like it has a mis . Any suggestions where to start for easy first then more technical
1 Post
You're probably referring to the distributor belt (the primary belt is connected to the secondary distributor by a small, rubber belt... they have been known to deteriorate and break). While the car will run on one distributor if the belt breaks, it might not run long and catastrophic engine damage can result. You should check that (a) the belt is intact (see thread) and, (b) that the distributor vent kit has been installed.
I don't think running on one distributor will affect the idle noticeably, but I could be wrong. Big rule of fixing things: Consider the simple things first.
