Problem with the roof
Hi Guys, I've got a problem with my roof.
Sometimes, when I pulse the roof switch, the only engines which work are the lock ones, and like in "phases", I have to pulse, and It moves a little, I pulse again, and It moves a little more, but the open/close engines doesn't work. When that happens, I move the car some meters, I wait sometime and It finally works. ¿What happens?
Another problem is.. When I switch the lights, the instrument light only switch on with the "position" or "first light/selection", with the "crossing" lights or "second selecction" the instrument light switch off.
Regardss
Regardss
Burgled
It sounds like you have bad solder joints in the control box under the dash. It is a common failure. They need to be resoldered. I am having the same type problem on mine now.
Burgled
