cat bypass with g-pipe?
#31
Hi Wolv,
I do not see any reason it would not work on a C4. The cat's are exactly the same and once you get back behind the rear wheels, C2 and C4 are the same. I would suggest one like the Dansk though as it has an internal muffler that may help a little with sound. Otherwise, price might be the factor.
#32
Duck, yea I thought they were the same. Thanks for clearing that up.
As for the Dansk ones, muffler to reduce the sound? I don't really mind it loud to be honest and yea, it would cost around $200 or so more no?
#33
I would say the Dansk type is more common in the US due to its appearance as a real cat. So I am not sure about a straight pipe. I am pretty sure the Dansk has an internal tube with holes that may help reduce the sound a little. I am not sure how significant it is. I had one on for a few months, but decided to go back to a regular cat.
#34
That was Ian. He phoned me that morning from Bedford while you were waiting for the mist to lift to say you were there. He also met me few miles down the road from your place and bought me lunch on the day I picked up the 964 from you. Ian, myself and bunch of others are going to Rockingham on the middle Saturday in August. Let me know if you're interested?
#35
Freedman,
Thanks for your help, am I right in saying this part is the same as what some refer to as the cup pipe?
The g-pipe replaces the box before the tail pipe and this de-cat /cup pipe thingy goes before that.
Also chopping the air box lid is it better buying the fabspeed fancy carbon lid thing.
Gaz
Gaz
#36
Chopping the air box is $175 savings over carbon one. Though once done, there is only one way to go back - buy a used one. Actually I cut mine and looking to go back to the standard. But it is not high on my lists right now.
#37
Freedman,
Gaz
Gaz
Not quite
De cat replaces the Cat which is before the primary silencer (sits under the nearside rear)
Cup pipe, replaces the primary silencer (runs across theback of the car)
G Pipe replaces the secondary silencer, (under the offside rear connected to the exit pipe)
Cant comment on the airbox as Ive never tried it, but lots of people just drill holes in the standard box
Regards
Gary
#39
I think I'd give this a try instead of spending nearly double on a Dansk one
http://www.haywardandscott.com/porsc...-pipe-crp.html
Will be slightly louder than one with baffles, but Ive got this style plus a G pipe and its perfectly acceptable
#43
