WEVO motor mounts
Blue. That's what I have on my 911.
Given your avatar, I'd say blue.
From Wevo:
I don't know how to quantify 15 points harder/softer on the Shore "A" scale for durometer readings?
I had sagging stock mounts. Replaced them with Wevo MM with black pillows... wow, really tightened up the car. The new mounts also make on/off throttle transitions much more direct... instead of the engine flopping around. Black pillows are completely streetable (though a bit louder in the cabin), but if I had a more track-focused car I would buy the blue pillows.
This is worth considering: (from Wevo)
From Wevo:
“Black” Pillows are 15 points softer on the Shore “A” scale for durometer readings than the original "Blue" Pillows. The Black pillows function in the same way as the Blue pillows – although they allow slightly more deflection under similar loads – the advantage is lower noise transfer through the SS mount module.
Blue and Black pillows can be mixed in any combination – including mixing them within a single mount body.
