Air Recirculation Button Fix?
The Air Recirc button on my AC panel is broken and won't stay in place on the switch. It appears that a piece has broken away on one side of the button and it can't clip into place properly. I can't source just the button and would be forced to replace the entire panel if I can't figure out a reasonable way to keep the button in place. Any ideas? (or spare buttons?)
Steve,
The switches, complete with buttons, are available separately from the dealer. There are only 2 button variations shown on PET for the US market so it shouldn't be difficult to establish which you need.
Regards
Dave
Regards
Dave
Thanks Dave. I was going by what was told to me by a US based wrecker/reseller who wanted $750 USD for the whole assembly.
I just got off the phone with the local dealer and indeed the switch can still be had at $236 CDN plus taxes. (yikes!).
While that is still expensive for such a rarely used item in a cab I am now at the point where I could try something like an epoxy fill on the button to hold it in place and buy a new switch if things didn't workout. I'd still love to hear if anyone else has tried something similar or has a spare switch/button kicking around.
The buttons were available on eBay recently. Do a Porsche 964 search. It's a ine drawing for the picture.
I searched for over a year before I located a "defective" CCU from a fellow R'lister. Bought it at a good price just for the two small buttons.
The buttons have a couple of light bulbs behind them with a small spring that compresses against the back of the recess and (I think) a flat plastic plate with tabs on the sides. They are positioned on a thin piece of the plastic plate that allows them to compress then slide into holes in the sides of the recess, one set at OFF and one at ON. Be careful not to let the small spring shoot out of the recess if you try to remove the button and repair the tabs.
I heard you could get them from the dealer for about $75.
It may be less expensive to order the switches from the UK.
94465392200 tip switch air conditioner £56.59
94465392100 tip switch £103.74
The are ex-tax prices but you would not pay the tax if ordered form the US/Canada
Go to www.design911.co.uk
Regards
Dave
Regards
Dave
hamah, if you're cheap like me, PM me if you would want to try to repair the one you have. I may have the part of the switch that's damaged. I could check on it this weekend.
I just had trouble paying what seemed like gemstone rates for such a small, crudely designed part. I felt like I got my money's worth with the entire CCU. At least I can send it in for repair and it will be worth more than the cost + repairs, making the buttons "free".
This is what you want:
http://cgi.ebay.com/ebaymotors/ws/eB...ht_1040wt_1165
Very expensive IMO but it's your money
951s and 944s use the identical switches/buttons (same part number). Mine were scratched so I found a cheap 951 control panel, removed the switches (they simply plug in to the base circuit card), then resold the working 951 control panel. It ended up costing me about $30 for both switches.
I've been looking for one myself since my was scratched up pretty bad by the PO. $100 new.
http://cgi.ebay.com/ebaymotors/Porsc...item3eedf8a669
EDIT:
oops I missed the enlargement and in fact both the Air Recirc and Defrost switches are in the single housing. I still think that is steep for the switch considering I'd likely never use either one but I'm at bit OCD
