964 Forum 1989-1994
front windshield
Old Mar 21, 2010 | 11:02 PM
stevepaa's Avatar
stevepaa
Default front windshield
I replaced my rear windshield about 2 years ago and now doing my front. I have over 200 k miles and the windshield has many pits which cause poor vision in the direct sunlight.
so here are some pics.
The most work is done removing all the old adhesive. I suspect the shops do a cursory job and just add more. The remover from Germany works well. Use a plastic stick to remove the bulk of the material and the remover on a cloth is used to remove all residue.
Old Mar 22, 2010 | 01:27 AM
altarchsa's Avatar
altarchsa
Thanks for posting.
Please update with progress. Last time I tried doing my own windshield on a 75 S, back in '88, I had to buy two windshields. But I'm hard to convince and would like to do my C4 myself.
Old Mar 22, 2010 | 03:27 AM
stevepaa's Avatar
stevepaa
I don't expect any real difficulty. This will be my third one. It just requires patience and correct technique to install. And I keep my toes and fingers crossed.
Old Mar 28, 2010 | 01:49 AM
stevepaa's Avatar
stevepaa
finished cleaning all the adhesive off, trial fitted glass and punched hole for antenna lead, fed in the rope. will install Tuesday
old glass, with a few nicks. anyone want it? free, you pay shipping.
Old Mar 28, 2010 | 03:49 AM
cpace3's Avatar
cpace3
how much did it cost u for a new glass? my car has rust arround the windsheld and got to get it fixed.
nick
Old Mar 28, 2010 | 11:55 AM
stevepaa's Avatar
stevepaa
current best price I see is around $680, I paid $645 to dealer 2 years ago.
Old Mar 28, 2010 | 01:24 PM
cpace3's Avatar
cpace3
right on. thats not too expensive even thought u got glass from the dealer.
thanx for the info.
nick
Old Mar 28, 2010 | 03:18 PM
964russ's Avatar
964russ
In the uk a dealer glass is about £600, a copy made by the same manafac was about £200!
Old Mar 28, 2010 | 05:29 PM
polar964's Avatar
polar964
Is there any difference between the two then Russ, besides the cost of course?
Old Mar 28, 2010 | 07:06 PM
Dave White's Avatar
Dave White
I know the newer glass has a "P" in a triangle on it in the corner if it is Porsche, had to replace one in my previous 02 Boxster, most car manufacturers have their own special mark if OEM.
Notice the spray can says BS Remover, how funny!
Old Mar 29, 2010 | 05:57 AM
pncarrerars's Avatar
pncarrerars
Once you had removed the adhesive was there any sign of knife damage in the paint? When I did mine I noticed damage where the headlining had been trimmed. I suspect that this is the cause of some of the rusting problems that people have.
Pete
Old Mar 29, 2010 | 09:59 AM
JDD's Avatar
JDD
Would you describe the process of reinstallation?
Old Mar 29, 2010 | 03:06 PM
stevepaa's Avatar
stevepaa
Pete, no marks of any kind, very clean.
JDD
Reinstall is typical for all these types of glass.
Put rope into the rubber channel that will fit into the car,
put the adhesive in the window channel of the rubber,
install the window into the rubber
put adhesive in the car on lip from where you cleaned it off,
lubricate the rubber where it will slide into car with armorall or other conditioner
position assembly onto car
loop antenna wire into car
with slight pressure on outside of glass, more to keep window in rubber than to push window into car, start pulling rope ends to pull rubber onto lip
take care near antenna wire
wipe off any excess adhesive in car
come back and add adhesive from outside between window and rubber, and between rubber and car.
Clean off any excess adhesive/sealant.
Old Mar 29, 2010 | 04:46 PM
JDD's Avatar
JDD
Thanks for that Steve...
Old Mar 29, 2010 | 07:46 PM
CBR786's Avatar
CBR786
have to attempt this as well in the near future to address the old rust at the bottom of pillar issue. I take it the original rubber surrounding windscreen has to be destroyed cut to get the glass out ?
