ENGINE CARRIER PAINT OR SHOT BLAST
I am no engineer in this field etheir but I assume thats stainless steel is more expensive then mild steel.. Also exaust and headers which are made from stainless steel have to be able to cope with extremes of engine temps so if anything the mild steel will flex and crack easier then the stainless steel ...
I agree that the mild steel would flex and the stainless steel will not it is more rigid and thus might result in a seperation of weld I will keep an eye on it and see what happens ... if need be it will be done again but I will update people if this eventuality arises..
Good luck!
