Fan bearing advice.....
Registered User
Hi guys im going to install my new fan bearing today, i bought a shop press a couple of weeks ago. Does anyone have advice on how to best line up the screw holes in the bearing hub with the holes in the fan. I think if its off i wont be able to rotate the hub because its a tight fit.
IHI KING!
Take a 2" long 6mm bolt, cut the head off and make a stud. Thread it into one of the bearing's bolt holes. Use that stud to act as an alignment pin as you are pressing on the bearing. In my case, I had three studs available. I used all three.
Registered User
Thanks Rob thats what i was thinking.
Old Thread, new question.
I helped a friend disassemble his fan/shroud/alternator assembly last night in pursuit of a noisy bearing.
Has anyone ever just drilled out the c-clip and replaced the sealed bearing ($18) and c-clip ($0.0003) in the fan hub?
The whole press-the-$150-fan-bearing-hub-off-on process seems absurd in the pursuit of a bad $18 bearing.
Thanks in advance.
Thanks in advance.
IHI KING!
Can the cooling fan be replaced while the engine is in the car? Yes. See
https://rennlist.com/forums/964-foru...-video.html#10
https://rennlist.com/forums/964-foru...ing-sound.html
won't pressing on the bearing with that bolt screwed in ruin the threads on the bearing?
