964 Forum 1989-1994
Brakes locking up
Old 01-03-2010, 12:51 PM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Question Brakes locking up
First of all, HAPPY NEW YEAR!!
A question before I get under the car to check.
I replaced front brakes for big reds. Did something wrong because now, when I turn the steering wheel all the way in one direction while backing up or going forward the brakes lock up.
I am going to check that I did not installed the brake lines incorrectly but outside of that, what else could it be?
Old 01-03-2010, 01:37 PM
Indycam
Indycam's Avatar
Got video ?
Are the tires hitting the body at full lock ?
Are the big reds hitting something at full lock and bending / binding the discs ?
If you jack up the car and remove a wheel , does it still bind up at full lock ?
Old 01-03-2010, 01:45 PM
garrett376
garrett376's Avatar
Wrong spacers for the calipers, so they rub somehow? That would be my best estimate... or improperly offset wheels.
Old 01-03-2010, 01:54 PM
Wachuko
Wachuko's Avatar
Originally Posted by Indycam
Got video ?
Same wheels and tires as before. Tires are not touching the body at full lock.
I will put it on the lift and check.
Old 01-03-2010, 01:55 PM
Wachuko
Wachuko's Avatar
Question
These were taken directly from another 964 and installed on mine. Everything works fine until I go full lock...
Old 01-03-2010, 01:56 PM
Wachuko
Wachuko's Avatar
I will take photos/video when on the lift. Thank you!!
Old 01-03-2010, 03:43 PM
dutchcrunch
dutchcrunch's Avatar
Default brake lock up
perhaps the rubber brake line in the wheel wells are getting pinched at extreme turning of the wheel , as the line is pinching its actually causing the brake calliper to apply the brakes, makes sense?
Old 01-03-2010, 03:54 PM
Wachuko
Wachuko's Avatar
That is what I am thinking... But how can I get that wrong!?? Those have only one way to be installed.
Old 05-10-2010, 06:02 PM
Wachuko
Wachuko's Avatar
Angry
Well... looking up the parts number I see that Turbo models have a different brake hose. So all this time I have been having this issue because I forgot to compare the brake line part numbers and used the existing one.
In the different threads I read before doing the brake upgrade I never saw a reference to a different brake line... anyhow, going to order a set of lines today. I hope that resolves the issue.
It calls for 928.351.971.01
Old 05-10-2010, 08:39 PM
Wachuko
Wachuko's Avatar
Any comments from those that have done the change to Big Reds? Did you change your brake line/hose to the 928 or 959 part???
Old 05-10-2010, 09:14 PM
Wachuko
Wachuko's Avatar
Photos... wheel full lock to the right...
Passenger side:
Driver side:
Old 05-11-2010, 01:25 AM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
I used the ones in the 993T brake kit which I distinctly remember were longer than the stock ones I removed.
Marc
Old 05-11-2010, 11:19 AM
Wachuko
Wachuko's Avatar
Thank you Marc.
Old 05-11-2010, 08:37 PM
Frank 993 C4S
Frank 993 C4S's Avatar
Yes - changed them to the 993TT part.
Old 05-12-2010, 09:10 AM
Wachuko
Wachuko's Avatar
Cool
Ordering the new lines. Thank you guys.
Quick Reply: Brakes locking up
