What are the best "bang for your buck" 964 mods???
#46
It looks like the same power gains can be accomplished with a Steve Wong flash, it's hard to clearly see what power gains are from the $2000 MAF setup versus the flash that Vitesse does to get the MAF setup running.
So I believe my plans are as follows (in no particular order):
1. TPC Supercharger Kit
2. Lightweight Flywheel
3. Proper exhaust setup
4. Lighten everything
5. Coilovers
#47
After the MAF setup from Vitesse i have an HP of 292, i really dont think you can get that from an chip. But its not only the HP but al so the response of the gas.
#48
Garrett1021
check out the following for an explanation of #2
https://rennlist.com/forums/964-foru...-for-free.html
#49
Great information here...
So far I've deleted the cat and secondary exhaust and I can't get enough of it. Right now, the next thing is going to be a suspension+ new tires.
I do need to get a SW chip soon though, the 964 is burning much more gas than usual with the cat bypass....or maybe I'm just driving the car faster
#50
For me the best mods I've done to my 964 were the LWF (RS) clutch, a set of KW V3, the Steve W chip and primary and cat by-pass. Last year I removed the entire exhaust system and installed a new 2-in two-out FVD Brombacher ehaust sytem and this was by far the biggest improvement I've done to the car. Not sure of power increase (sure there is some) but the trhottle response was amazing very close to modern car, much more usable low-end torque as well. Not I have to send my chip back to S. Wong to have it remap for the LWF, the sport/headers exhaust system for hopefully more driving fun.
#52
I have done suspension, exhaust, wong chip and a ton of other mods. Always wanted the music to sound better for long trips and finally found the answer...subwoofer...biggest sound improvement I ever made since removing the factory setup...dont know how I ever did without it
#53
That is an easy question to answer it is weight reduction, start from the rear, and work upward and forward.
If you sell of some of the parts your remove you'll have more bucks to buy extra bangs which I would spend on good set of tyres, lighter wheels improved the suspension and a proper geo setup.
All of these mods will help improve acceleration, cornering, braking and the transition between each of them ie the whole time the car is moving
No engine or braking mods will have as big an effect for the same price.
Schlyter (09-21-2020)
#54
Engine rebuild with some performance upgrades (cams, manifolds, compression and some more...)
I've Never used her so hard before and i was never so relaxed before when using her quite hard :-)
Best 10k€ i've spent for the car after i bought her five years ago
#57
Lots of posts and I'm surprised not one mention of improving the driver. ;-)
