Recaro seat
#31
Here's an arrangement that I was unhappy w/
Stock 993 inner(8.25" from the mounting hole ctr to the end of the receiver). Even if it was longer it would still be at an awkward angle. The upper end is forced to angle away from the seat by the bolsters. On a wide seat there is also no room between the bolster and the center console
I alos did not like the final rocker position of the BK side mounts , they were discarded too.
While the harness clip would have worked ok, that was also redone by mounting reinforced pad eyes through the tunnel walls
#32
No joy.
Got the longer belt recivers from breakers, but my belts are different.
Looks like ive got red Rs belts, standard belts are different!
My belt receivers have 2 screw in the top, and r slightly wider.
I aint payin £400, so it looks like ill have to make do.
#35
hi guys,
sorry i was away, my receiver seams to be longer like on Bill's last picture the car is a 1992, i have the Brey Krauser hooks but did not use it as the belt snap hook would rub on schell, i just drill the floor at the back and put an eye hook, about the seats i sale them, they are comfortable the diff with PP is the shoulders are more forward so no slide on track...
Konstantin
Konstantin
#36
hi guys,
Konstantin
Konstantin
sorry but I didn't understand what seats are your's... I like 'em a lot...!
