FS: 964 RS sway bars
For Sale: 964 RS sway bars
1. 24mm 5-way front (964-343-707-70)
2. 18mm 3-way rear (964-333-701-70)
3. Poly bushings (OEM bushings included, too)
4. Left front drop link (964-343-071-80)
Not included: right front drop link (964-343-072-81), or you could use a Tarett front to eliminate the preload. OEM drop links work in the rear, or you can use Tarett rears.
Used for two seasons, but they aren't exactly wear items.
Asking $350 + shipping from 92064 (18#).
I saw this first thing this morning and thought what a great deal but I must resist! ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
It also got me looking at PET to check all the part numbers and for the first time I noticed that there is an M030 option for the front swaybar on a C2 - 22 mm instead of the standard 20 mm. PET also indicates that the M030 sway needs the drop links changing to those that are on the C4 which I found a bit confusing. Anybody have the M030 option on their C2?
While I was at it I also noticed that the RS has a different part number for the clips that hold the bushes. I guess that this is because the RS bushes are larger to compensate for them having a larger ID? Not sure if Kris is supplying the clips aswell as the bushes so it might be worth checking with him?
I have the M030 front bar and bushings and links on my car. It made a huge difference over stock but Ive been thinking I may upgrade to even larger bars eventually. I have resisted because the balance is perfect as she sits now.
While I was at it I also noticed that the RS has a different part number for the clips that hold the bushes. I guess that this is because the RS bushes are larger to compensate for them having a larger ID? Not sure if Kris is supplying the clips as well as the bushes so it might be worth checking with him?
