964 Forum 1989-1994
Vibration inside the shifter
Old 09-28-2009 | 10:16 AM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Question
Originally Posted by Indycam
"I would check the CV joints" CV joint problems are lower frequency than a "Sonicare" .
"40,000 strokes per minute"
"Change the transmission oil."
Are you thinking a bad bearing ?
Does the buzz change on different road surfaces ?
I would still check the CVJ... maybe he has an old model Sonicare or a generic unit
Yes. Changing the oil and checking for metal debris might help determine if the problem is inside the tranny.
Your toughts?
Old 09-28-2009 | 12:54 PM
bron964's Avatar
bron964
perhaps it's something much simpler...is your shift **** an aftermarket piece?
mine used to make the exact same noise you are describing because the tiny little screws used to hold the **** in place had loosened.
Old 09-28-2009 | 03:07 PM
Indycam's Avatar
Indycam
Your toughts?
My thoughts are that there is a vibration , it could be a normal or abnormal vibration and its getting telegraphed up the shifter linkage parts , causing the shifter to buzz .
I think I would put the car in neutral and run the motor to see if I could get the shifter to buzz . If it will buzz when in neutral ...
Old 09-29-2009 | 01:18 AM
psiegel's Avatar
psiegel
The shifter is stock. No noise when I out the car in Neutral. I did replace some of the cv joints, I don't remember which one's (I'll need to check the work order) about a year ago.
Thanks all for the suggestions.
Old 09-29-2009 | 03:41 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
I had this on my second 993 -- it was the engine mounts
Quick Reply: Vibration inside the shifter
