hamsters in the heater.
Hi,
Only joking the little fellas aren't in there,but the heater in the 964 is really noisey the one in the scuttle rhd side in the front.Can anyone tell me what it takes to get to it and lube it or is it a new bearing I need.
Regards Gaz.
Regards Gaz.
I don't believe they can be lubed - but I have kind of lubed mine.
From memory - remove the fuse box (rest the fuse board on the wing / fender). Remove the firewall.
This gives access to the fan on the RHS. You can unclip the cover. I sprayed plenty of grease onto mine, which did quieten it down for a few months but it's really only a temporary bodge.
Oh - and you can't replace the bearing, you need to replace the fan, which at least in the UK is not cheap. I did intend to get mine done, but it had to be ordered from Germany - and wouldn't have arrived before I was taking the 964 on a weeks holiday. I had to bodge it, or I'm pretty sure I would have driven it off a cliff - mine had got very loud!
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Thanks,
anyone got any photo's of this task as its not going over the cliff just yet, but I will repair it,the motor must be repairable or who's bought one in the uk at a non porscher inflated price.
Thanks in advance Gaz
ps;photo or picture of motor would be handy info.
Hi,
Thanks for the thread,will study tonight when home from work in depth.
The car doesn't have air conditioning so its a basic get the hamster wheel out refurb it or feel the pain and buy another.
But many thanks for your help
Gaz
Gaz
Professor of Pending Projects
Those are expensive hamsters....
![](http://forums.rennlist.com/upload/airboxremove_copy3.jpg)
![](http://forums.rennlist.com/upload/fan_3_copy2.jpg)
I look back at the photos and I just don't know how the heck I built up the courage to do that task...
Those hamsters are getting more expensive every day...Vertex currently lists them for $549 and $649.
Has no one figured out a way to rebuild them? I can't believe it would be impossible.
Thanks,,
The info is helping me build the confidence to get at this at the weekend,I will recondition this motor when I get it off ,mine is working but very loud.
I hope I can turn a bush down out of nylon or drill it out and put a bearing in.
As the above post we should be able to do a repair to it.
Regards Gaz,,,
Regards Gaz,,,
