Petrol Smell in Cabin & Engine Bay
I know this is a recurrent question but despite checking all the fuel line connections, changing the petrol cap and checking that the latest type of filler neck is fitted (it is) I am still getting a petrol smell in the cabin and in the engine bay after a drive. My questions are:
1. Is your car free of any fuel smell or do we all get a bit of odour?
2. Has anyone changed the carbon filter in the rear wheel arch to solve this problem?
What else can I do to solve this? Thanks...
Had exactly the same on my newly acquired C2 - turned out to be the plastic valve that sits right on top of the fuel tank expansion chamber (sits in a rubber grommet with a 90 degree bend top and bottom with rubber pipes connected to it) had a crack in the plastic outlet on top, thus breathing petrol fumes into the car!
New one cost me £23 in UK and fitted it in 15 mins, now all sorted.
Good luck
Good luck
I have the problem of fuel / petrol smell in the cabin just at start up and once i'm driving (with windows down) the smell goes away. Will check the 90 deg plastic part for cracks etc.
Appletonn, would you have pictures of the fix?
thanks!
thanks!
Where is this carbon filter? For some I was led to believe there was no cabin filter to clean/replace. Best of luck with the troubleshooting. I just thought it was normal to have a slight oil/fuel smell in our cars. That is part of the charm.
Neil
One other thing to check(after looking at hose connections etc...) is the banjo fitting on the fuel pump. I've seen these loosen up slightly, enough to give an occasional drip of fuel, but not enough to accumulate on the floor. Check for tightness.
IHI KING!
https://rennlist.com/forums/964-1989...placement.html
My car has that distinct "porsche smell" as well and have been contemplating the fillerr neck replacement.
Just went and checked that shut-off valve on top of the expansion chamber (#10) below and its real easy to pull up from where it sits. I suppose that means its probably broken?
Add another thing to the winter list.
Professor of Pending Projects
Good luck
Good luck
Order of troubleshooting (from free to more expensive...):
1. Check the condition of all hoses, and that all hose clamps are secured. This also includes the tube going to the carbon canister, and removing bottom cover to check fuel pump area.
2. Fuel cap seal. This seal can be purchased separately for around US$3-4.00 or you can just buy a new fuel cap.
3. Vent valve at the top of the small fuel tank on the drivers side could be craked. Part No. 964 201 175 01 (This is a US$30-40.00 part)
After all this I suggest you remove the trunk carpet and give it a shampoo and let it air dry completely before installing... sometimes you remove the source of the leak but keep looking because the carpet still has the gas smell.
All these steps will help you eliminate the smell. But if your significant other has grown used to your oil and gas smell, well... you can bring back that fragance by mixing one part gas with two part oil and placing small drops of the mix behind your ears, neck, and the back of your knees... drives them wild!
I noticed the same problem 2 months after purchasing my '89 C4. Replacing the gas cap did not help so I took the car to a smog check shop. They pressurized the system and found a leak in a vapor line under the driver's door. My mechanic replaced the deteriorated line and within a week, the smell was gone.
Newsboy, I would be interested in more information about the banjo fitting you are discussing as I am almost out of things to check or replace except the tank itself and I have had it pressure checked.
