odd whistle
odd whistle
I have been hearing an odd high-pitched noise that varies with engine speed. It seems to come from the LH side of the car. I thought maybe the radio was hearing an RF and it was coming through the door-mounted tweeter, but it carries on with the radio off.
My first thought was that it was the air-flapper-whistle some have identified, but it varies with engine speed, not road speed.
Any Wise Thoughts?
Any Wise Thoughts?
See if it isn't your fan belt roller sensor.. Turn off the car - and take a tie wrap and tie the roller/pulley slightly off the belt (so it doesn't rotate). Start the car and see if it still whistles. Once you figure out if that's the issue - remove the tie-wrap..
JD
JD
Hard to replicate when stationary w/out wincing, but it comes through loud & clear in first gear. Really comes in about 2,500-3,000 rpm, rises in pitch with engine speed.
IHI KING!
Not sure I understand why its hard to replicate with the car is stationary? I was thinking that if it makes the noise while stationary, then the problem is some how related to the engine because the driveline is stationary when the car is stationary.
Can you put the car in neutral, set the hand brake, radio off, HVAC off, roll the windows down and then rev the engine to 3,000 and then back to idle? If the noise does not occur, then try turning on the radio and repeat the test. If nothing, turn on the HVAC and repeat.
I'm suspecting that you may be hearing a noise through the heater/ac ducting. My cabrio has a slight whistle because of a small tear in the cooling shroud boot.
IHI KING!
Sounds like you have eliminated the drive line (wheels, brakes, tranny, etc) as a cause. After you have tightened the hose clamps, let us know if the problem is solved or not.
I think Rob is right on target since it's not the roller wheel.
As it acts as an air whistle - rather than a mechanical issue - I'd be interested as well... And Rob? You are in Nashua?? Dang - howdy neighbor!!
John
John
