964 Forum 1989-1994
Nuts and Bolts
Old May 28, 2009 | 08:13 PM
tgage's Avatar
tgage
Default Nuts and Bolts
While waiting for a replacement oil line part from Germany to arrive, I decided to drop the engine and deal with a few other oil leak issues, valve adjustment, repainting the tins.... you know how the slippery slope goes... but I did not see any reason to pay a premium for replacement bolts and nuts for the covers and mufflers etc.
I went looking back at a few old posts on getting replacement nuts and bolts, tried a few of the links and became frustrated with the ordering process of the suggested vendors. I then tried www.nutsandbolts.com (No affiliation) who have an online shopping cart and came up with the below list... but they don't appear to sell bolts with the cadmium coating, just zinc. I have not purchased these yet. The ones below are all 8.8 (except the stainless).
Other than Ace Hardware, where do you guys buy replacement nuts and bolts? I was thinking it would be cool to have a nuts and bolts replacement kit for our cars.
tom
M6 X 1.0 Metric Hex Nuts Qty (50)
$3.02 $3.02
M8 X 1.25 Metric Hex Nuts Qty (25)
$2.82 $2.82
M6 x 1.0 Metric Nylon Lock Nuts Qty (50)
$3.60 $7.20
M8 x 1.25 Metric Nylon Lock Nuts Qty (25)
$2.95 $2.95
M6x1.0x10 Stainless Metric Cap Screws (Hex Bolts) Qty (1)
$0.22 $5.50
M6 X 1.0 X 10 Metric Hex Bolt / Hex Cap Screw Qty(50)
$11.16 $11.16
M6 X 1.0 X 12 Metric Hex Bolt / Hex Cap Screw Qty(50)
$11.80 $11.80
M6 X 1.0 X 16 Metric Hex Bolt / Hex Cap Screw Qty(50)
$12.13 $12.13
M6 X 1.0 X 20 Metric Hex Bolt / Hex Cap Screw Qty(50)
$12.60 $12.60
Sub-Total: $69.18
Old May 28, 2009 | 08:27 PM
parsecnc4's Avatar
parsecnc4
http://www.mcmaster.com
And I also buy various Viton O-rings and odd ball stuff from them on occassions.
No affiliation... etc...
Old May 28, 2009 | 08:53 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I buy most of my nuts and bolts at my local hardware store.
Old May 28, 2009 | 09:55 PM
Bates's Avatar
Bates
I sell fasteners for a living, not selling here, though.
All of these parts are readily available, however, when you need just a few of each the price multiplies dramatically. I probably pay $14/1,000 for a steel zinc plated M6 hex nut. You pay dearly for someone to bag just a few and keep them in stock.
Hardly anyone will plate with cadmium because it is known to cause cancer. Ironically, the largest user of cad plated parts is the US military. Zinc plating has been bastardized by the European market (so the USA can meet ROHS compliance). Classic zinc plating contained hexavalent chromium (think Erin Brokovich) which has been changed to trivalent...what you will see is your standard steel zinc fasteners will rust sooner than before, but there are less toxins in our landfills when they are discarded.
Buy fasteners where you can get them, stick them in styrofoam and paint the heads with Rustoleum. That will be your best way to prevent rusting easily... or pay for stainless where strength is not critical.
My 2 cents worth, or in this case an M6 zinc hex nut!
Old May 28, 2009 | 10:45 PM
tgage's Avatar
tgage
Thanks Guys... All good advice. I did not know about the cadmium thing.. thought that was the only way to get the gold color bolts. Our local ACE Hardware has most bolts in stock, but they will run 35 - 60 cents a piece.
I just placed an order at mcMaster which had a wider selection. Incase anyone is interested, here are the part numbers that are pretty typical on our cars. The only one I was not sure about were the set screws for the muffler... a bit of a gamble there.
Line Quantity Part Number Description Unit Price Total Price Ships
1 1
Pack 91280A322 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M6 Size, 10mm Length, 1mm Pitch, Fully Threaded, Packs of 100 $4.66 $4.66 in the morning
2 1
Pack 91280A325 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M6 Size, 14mm Length, 1mm Pitch, Fully Threaded, Packs of 100 $6.21 $6.21 in the morning
3 1
Pack 91280A326 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M6 Size, 16mm Length, 1mm Pitch, Fully Threaded, Packs of 100 $8.65 $8.65 in the morning
4 1
Pack 91280A324 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M6 Size, 12mm Length, 1mm Pitch, Fully Threaded, Packs of 100 $5.05 $5.05 in the morning
5 1
Pack 91280A540 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M8 Size, 35mm Length, 1.25mm Pitch, Fully Threaded, Packs of 50 $9.84 $9.84 in the morning
6 1
Pack 91280A542 Metric 8.8 Zinc-Pltd Steel Hex Head Cap Screw M8 Size, 40mm Length, 1.25mm Pitch, Fully Threaded, Packs of 50 $12.30 $12.30 in the morning
7 1
Pack 90591A151 Metric Zinc-Plated Steel Hex Nut Class 8, M6 Screw Size, 1mm Pitch, 10mm W, 5mm H, Packs of 100 $2.19 $2.19 in the morning
8 1
Pack 90725A043 Metric Zinc-Plated Steel Heavy Hex Nut Class 8, M6 Screw Size, 1mm Pitch, 10mm W, 6mm H, Packs of 100 $6.33 $6.33 in the morning
9 1
Pack 90591A161 Metric Zinc-Plated Steel Hex Nut Class 8, M8 Size, 1.25mm Pitch, 13mm W, 6.5mm H, Packs of 100 $4.83 $4.83 in the morning
10 1
Pack 90725A715 Metric Zinc-Plated Steel Heavy Hex Nut Class 8, M8 Screw Sz, 1.25mm Pitch, 13mm W, 8mm H, Packs of 50 $10.62 $10.62 in the morning
11 1
Pack 90576A115 Metric Zinc-Plated Steel Nylon-Insert Locknut Class 8, M6 Sz, 1mm Pitch, 10mm Width, 6mm Height, Packs of 100 $4.09 $4.09 in the morning
12 1
Pack 96817A510 Metric High-Performance Thread-Forming Screw M4 Thread Size, 10mm Length, Packs of 10 $7.58 $7.58 in the morning
13 1
Pack 91287A134 Metric 18-8 SS Hex Head Cap Screw M6 Size, 12 mm Length, 1 mm Pitch, Fully Threaded, Packs of 50 $6.30 $6.30 in the morning
14 1
Pack 91390A150 Metric Alloy Steel Cup Point Socket Set Screw M8 Size, 40mm Length, 1.25mm Pitch, Packs of 25 $13.03 $13.03 in the morning
Merchandise Total $101.68
Old May 28, 2009 | 11:04 PM
Bates's Avatar
Bates
Most "gold" hex bolts are plated with zinc dichromate. The main reason this is used is to quickly distinguish a grade 8 bolt (yellow) from a grade 5 or 2 (both silver).
Old Jun 2, 2009 | 04:47 PM
parsecnc4's Avatar
parsecnc4
I am glad McMaster worked out for you. It is like a candy store for many odd-ball hardware bits & pieces.
Old Jun 2, 2009 | 04:51 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I recently found another source. I see their building on my commute to work each day. I haven't used them yet but they seem to have a wide selection.
http://www.belmetric.com/
No affiliations.
Old Jun 2, 2009 | 08:38 PM
boxsey911's Avatar
boxsey911
Similar to tgage, I'm not adverse to buying a few nuts and bolts from Porsche to use when doing a job on the 964. But when I was quoted over £6 for a captive nut and £4 for the bolt to go in it....I thought enough was enough. A quick search around ebay and the web saw me acquire a ruck of u-nuts (spire clips), bolts, lock nuts, self tappers (hex head and posidrive) for the price of 8 Porsche captive nuts!
Old May 21, 2018 | 04:15 AM
John McM's Avatar
John McM
Well it took a spam post to revive this thread but I’m intrigued at the real posts. This is a real pain when doing something like a full engine rebuild.
Old May 21, 2018 | 08:51 AM
Alex Sol's Avatar
Alex Sol
i bought almost everything from EBS Racing. They were quite reasonable and recall paying 50 cents for copper hex nuts for the exhaust vs... $5.00 locally !! overall cost i found reasonable. but did not get the $14 / 1000 price.
Old May 22, 2018 | 12:57 AM
Super90's Avatar
Super90
I purchased a lot of fasteners from BelMetric. RM European has reasonable prices on some very specialized bits, then there are some I just see my local Porsche dealer parts guy. He's been very helpful.
