Does my new helmet fit?
Super Duper Moderator
I posted this to the Racing forum for opinions there too.
I am not sure if my new Arai GP5W helmet fits or not. I am purchasing a new helmet to replace my aging Bell M2 which was a size large, I think.
I measure my noggin and according to the fitting chart, 58 cm equates to a medium Arai.
The new Arai arrived today from Apex (Great service from Linda) and it is certainly snugger than my Bell. I wore it for 30 minutes around the house and is seems very comfortable but the only issue is it seems to squish my face at the angle of my jaw. After having it off for a while now, my jaw seems a bit achy, like it is tired.
Will the inside compress a bit? Is the new helmet too small or was the old one just too big?
Marc
Marc
like getting a new pair of shoes....
you have to break them in.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
also the newer helmets fit tighter than the older ones....newer specs for impact absorption...
I bought a new Pyrotect with Snell 2005 rating...much tighter than my old HJC...with the 1995 Snell rating. More padding in the new one and much tighter.
It will break in. My new Pyrotect took about 1/2 of a season last year to really get comfortable.
Former Vendor
It sounds like it fits you pretty comfortably. The "problems" you are describing are probably small details that you will all forget, the second you get out of pit lane. Most (at least the ones I have been to) sessions are only 20-30 mins long. So if you've been able to wear the helmet around inside the house for that long, then I don't see any problems with it. Also, like you mentioned, it'll probably only get better with time, as it stretches out to your face a bit more with use.
-Don
-Don
I have an Arai motorcycle helmet and it to is tight on my face. Squishes the cheeks a little bit, but is very comfortable. Like mentioned above you need to break it in a little bit. Arai are great helmets, vents, washable liners and look nice too!
My GP5W is the tightest fitting one I've also ever had (have had about 8 over 25 years). But also the best fit. I've debated on the cheek pads; it's not much of an issue a year or so later.
