how do you remove doorlight switch?
all,
how does one remove the door mounted interior light switch without destroying it?...i haven't messed with it yet.
i'm familiar with the 356 style which has a hex nut
wm
wm
door frame/jam switch
The manual describes the process - although not terribly helpfully. I tried sticking the screwdriver in the long end, and cracked part of the plastic (oops). I think best to lever out from the sides (very carefully) - ie, not what I did. Would defer to the comments of those who have successfully removed without breaking it first...
IHI KING!
Its been a while since I did it on my '90 C-4. The process was simple. The trick is realizing that the aluminum disk is threaded like a nut.
Step 1 - Remove the rubber boot/cover
Step 2 - With some large adjustable pliers, twist off the aluminum disk
Step 3 - Slide the switch out
Installation is the reverse.
I hope this helps.
I hope this helps.
thanks!
