964 Forum 1989-1994
Low...is Low!!!........at last
Old 03-26-2009, 03:00 PM
  #31
PorscheCarrera964
PorscheCarrera964's Avatar
Originally Posted by ABQ Slim
LMAO
Will Smith and Martin Lawrence? Butch and Sundance? Jeff Daniels and Jim Carrey? Mel Gibson and Danny Glover? PAH! Fox Searchlight presents the cop buddy movie of the year -
THE RIDE HEIGHT BROTHERS
"Sorry, Cap'n - we woulda had them bank robbers but we had to angle crawl over the speed bump at the end of the drive-through lane!"
Coming to a drive-in theater near you.
Whichever floats your boat lol, I am too young to know ANY of those dazzling duos other than bad boys, simply bc of the 965. I would say martin and will, but i am white, so that doesnt work. all that was before my time, but none were brothers i assume batman and robin? Of course id be bruce, bc robin has no purpose in life!
Love te stance low!!!
Our heigjt is the same, unless i take the front down more, justto hear more people complain abt the height not being track-able!
Old 03-26-2009, 07:39 PM
  #32
boxsey911
boxsey911's Avatar
Originally Posted by Low 964
What are your arch to ground heights (I know this isnt accurate)..I am 615mm rear and 620-25mm front (24.25 inch 24.5 inch)
As you say it isn't accurate but I've measured mine for you and I'm 625 mm rear and 635 mm front. You've got nearly a whole half inch on me boy!
Old 03-26-2009, 07:47 PM
  #33
Low 964
Low 964's Avatar
Thing is a full tank can loose 7mm, plus luggage and 2 people, and settlement , so it changes a lot, .........A guy locally and Rennlister has 610 up front, but tyres seem lower profile than mine......
Old 03-26-2009, 08:42 PM
  #34
boxsey911
boxsey911's Avatar
Very true. My official readings with a quarter tank were 120 mm front and 223 mm at the rear. i.e. I'm RS height at the rear and 5 mm lower at the front. My initial caster was set at 4 35 at the front but I was getting rub on one of the wheel arch liners so this was reined back to 4 25. We subsequently found that the rub was caused by a bent wing (fender) stay. Now this has been sorted I may try the 4 35 again because it gave a much nicer weight to the steering....And before our friend A964man asks ;-) ..I didn't write down the camber and toe measurements but I think they're standard C2
Old 03-26-2009, 10:31 PM
  #35
PorscheCarrera964
I am 24.5 from ground the fenderwell rear, and 24.25 front, with 18s, but my tires arent really that thick
Old 03-26-2009, 10:58 PM
  #36
mojo747
mojo747's Avatar
How much harsher is the ride when you slam it? I'm running 18's and the ride suffers slightly. I like the low look but don't want it to ride like rock if I lower it.
Old 03-27-2009, 12:34 AM
  #37
PorscheCarrera964
My car rides exactly the same as it did before, Its slightly, literally SLIGHTLY stiffer, not bouncy, not bumpy, doesnt rub etc----I cant tell a difference other than the fact now it doesnt look like a 4x4, you def need to lower the front for sure
alabama huh? Thats where I drove to get my boxer, all the way from Tampa, there are some badass driving roads there!
Old 03-27-2009, 05:56 AM
  #38
Low 964
Low 964's Avatar
Mine is fine...ok you do have to watch the pot holes, and mine is set hard....but I want a racing car not a family tourer. Its not as good on the rough but better on the smooth.........but it looks great now.
Go Low............
Old 03-27-2009, 06:53 PM
  #39
demonfish
demonfish's Avatar
i've banged the R888's on (stiff sidewall) and ramped the dampers up to 9 and 7 - what a difference
Old 03-27-2009, 06:54 PM
  #40
kos11-12
kos11-12's Avatar
Hi guys,
I run KW V3 quite low with 18" it is much harder, not that I mind but geo, setting and tyre pressure(34/36 for me) is more tricky, bump steer is more noticable.
Konstantin C4 92
Old 03-28-2009, 12:12 AM
  #41
mojo747
mojo747's Avatar
Yes. There are alot of sweet two lanes in Alabama.
Old 03-28-2009, 06:10 AM
  #42
Low 964
Low 964's Avatar
And a "Freebird"
Old 03-29-2009, 10:23 AM
  #43
mojo747
mojo747's Avatar
I moved here 20 years ago from Rhode Island . I'm what they call a Damn Yankee.
Old 03-30-2009, 10:58 AM
  #44
Ant71
Ant71's Avatar
Pete your car looks great!
Old 03-30-2009, 06:33 PM
  #45
Low 964
Low 964's Avatar
Cheers Ant, you still got the 964 then, are you gonna take it to the meet in April, near Leicester?
Quick Reply: Low...is Low!!!........at last
