964 Forum 1989-1994
Help with Brembo part #
Old 03-17-2009, 06:50 AM
Bill Verburg
Bill Verburg's Avatar
Originally Posted by Jonnygo1
Here's the photo, sorry.
That is a 928S4/993 front caliper, S4 istrailing mount 993 is leading mount, the same caliper w/ raised bosses is used on 964 3.3t and 964RS
Old 03-17-2009, 09:54 AM
Ritter v4.0
Ritter v4.0's Avatar
Don't you have an orange theme going?
Old 03-19-2009, 04:02 PM
Jonnygo1
Jonnygo1's Avatar
Which parts other than the carrier, hub and bearings will I need if I just want to go with the standard 993 carrier? Will I have the same issues with the struts as those with the evo uprights?
Old 03-19-2009, 04:56 PM
Bill Verburg
The aluminum 993 and 993RS wheel carriers are slightly thicker at the mounting boss than the steel 964 versions, so you ought to use 993 struts which have wider spacing on the mounts. Some have done it w/ 964 struts as documented here, if using the 964 struts the lower mounting bolt need to be changed to a 14mm version.
There are no issues that I am aware of using the 993RS(aka evo, GT2) uprights other than that you need the straighter outer tierod ends but yes both 993 ans 993RS are aluminum w/ the same thicker mounting boss.
Old 03-19-2009, 05:44 PM
deoxford
deoxford's Avatar
You mean pink
Old 03-19-2009, 06:33 PM
Jonnygo1
Jonnygo1's Avatar
Originally Posted by deoxford
You mean pink
Boy, you guys are tough!
Old 11-20-2009, 02:58 PM
C4S993
C4S993's Avatar
I looked everywhere and I cannot figure out what the 993 Big red pad retainers bolt specs, are they Torx and if so which T-? are they, thanks,
Patrick
Quick Reply: Help with Brembo part #
