Bone Stock or Mods?
#31
Super Duper Moderator
Everything is totally stock......except for the bits I modified.
Internal Engine Mods:
Pauter rods
ARP rod bolts
ARP head studs
Jerry Woods valve springs
Ti retainers
External Engine Mods:
Rothsport RS hub
Rothsport light-weight crank pulley
RUF secondary oil cooler
OE oil cooler fan over-ride
Wevo SS engine mounts with blue pillows
Optima Red-top battery
IA upper & lower billet valve covers
Dual vacuum reservoirs
Rear blower delete
A/C delete
Exhaust:
Ceramic coated Fabspeed headers - no heat
Ceramic coated Fabspeed dual outlet exhaust
Cat delete
Transmission Mods:
RS clutch
Light-weight flywheel
Steel synchros
Billet shift forks
Suspension Mods:
JIC Competition coil-overs - 15/1 way adjustable
JIC custom 500/780 in-lb springs
JIC camber plates
TRG anti-sway bars (25mm front/22mm rear)
Tarrett Engineering rear drop links
ERP spring plates
ERP needle-bearing bushings
Turbo tie-rods
PerfectPower strut brace
Stage 8 locking CV joint bolts
993 steering rack brace
Euro RS aligned & corner balanced
Brake Mods:
993 Turbo Big Red calipers front
964 Turbo red calipers rear
PowerSlot floating slotted rotors - front (322x32)
PowerSlot slotted rotors - rear (299x28)
Goodridge stainless brake lines
Pagid RS19 front & RS14 rear brake pads
Castrol SRF brake fluid
Custom PDAS/ABS over-ride
Proportioning-valve delete
Body Mods:
Aero mirrors
TechArt FRP front splitter
MAShaw RSR brake ducts
Custom front air intake
Clear front indicators
Front bumperette delete
Silver hood badge & rear script
Rennline tow hooks
H4 conversion with 85/120W headlights
Custom manual spoiler control
Rear wiper delete
Wheels
18x8 and 18x10 MY02 5-spoke red & Hoosier R6 tires (245/275) - track
18x8 and 18x10 MY02 5-spoke black & Hoosier Wet tires (245/275) - track
18x8 and 18x10 MY02 5-spoke black & Michelin Pilot Sport Cup tires (245/285) - track
18x8 and 18x10 Fikse Mach V & Michelin Super Pilot Sport tires (245/285) - street
Interior Mods:
Recaro SPG seats
Recaro brackets & sliders
Schroth Hybrid Profi-II 6-point harnesses
DAS bolt-in roll bar
Momo Mod 07 steering wheel
Rothsport QR hub
RS manual window lifts
RS door panels
Rennline aluminum floorboards
Rennline adjustable pedal set
CoolSuit Club12 system
TraqDash/TraqMate data logger
GoPro Hero2 HD video system
Zeitronix/DashDaq engine monitor
Aerospace Logic 6-cylinder CHT gauge
2.5 lb Halitron fire extinguisher
RS Perlon carpet
Custom wiper over-ride
Stereo and speaker delete
Sound insulation delete
Lower dashboard delete
Rear seat delete
Down to 2930 lbs and dropping fast so I can win my next DE, damn it!![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Oh yeah, and about 45 lbs less than a C2 RSA!
Marc
Pauter rods
ARP rod bolts
ARP head studs
Ti retainers
Rothsport RS hub
Rear blower delete
A/C delete
Exhaust:
Cat delete
Transmission Mods:
RS clutch
Steel synchros
Billet shift forks
Suspension Mods:
JIC camber plates
ERP spring plates
Turbo tie-rods
Brake Mods:
Body Mods:
Aero mirrors
Rennline tow hooks
Rear wiper delete
Wheels
Interior Mods:
Recaro SPG seats
Rothsport QR hub
RS door panels
RS Perlon carpet
Rear seat delete
Marc
#32
Nearly totally stock. Leftover Euro RS (street car) Bilsteins and some springs of unknown manufacture. Track worthy brake pads and decent fluid. Some Cup 1 replicas and RA1's. Second oil cooler, and it sure seems like it has a lightweight flywheel.
140K miles, and I'll run it straight up against anything that's a sub-20K car.
#34
I have the TRG front and rear bars. used the factory RS drop links. IMO the TRG front bar is too stiff and I need to run it at full soft withe the rear set at full stiff. They may work better with much stiffer springs but with the bilstein HD's and H&R reds, I think you are better off with a stiffer rear or softer front bar.
#35
I drove the car bone stock for a couple of years. Stock suspension is pretty good after you get the worn out shocks replaced.
Primary by-pass was first mod, and that is easy and reversable. Just did PS delete/RS manual rack, and RS pulley mod. No driving impressions yet. Car is still on jack stands waiting for me to finish up.
#36
Man, am I out numbered here.
But that is okay.
Mine is absolutely bone stock, factory everything, except the PO had an 8K paint job done. Original Amazon Green. Other than that, I did not put my undertray back on from my last valve adjustment.
Starting the mods thing is a slippery, slippery slope.....
But that is okay.
#38
TURBO CONVERSION
Lowered Compression to 8.5
Turbo - Garrett TO4B 70-1 Ptrim changed out to .58P trim hot housing
TiAl 41mm Wastgate - 1 Bar Spring
993 Mass Air Flow -Part # 993 606123 01
C2/C4 Mass Flow Software
Divider Network
993 Air Box - 99311036704
993 Air Temp Sensor - Part # 993 606 113 00
Fuel Pump 993 GT2 Twin Turbo Part #- 0580254044
Fuel Injectors - 993 Twin Turbo
Duel Oil Cooler Installation - 96420722002
Oiler Cooler Fan Thermo switch Modification ( 11k in series, on too hot), (2.2K in parallel on too cold), ( 1.1k parallel low 195 hi 210)
Intercooler - Custom stainless -full width
965 Turbo S Fixed Wing FVD 512965S- Cut Fab wing to fit
Air Filter- K&N RF-1003
TRANSMISSION
Clutch - All 996 GT2 Twin Turbo Components
GT 2 Pressure Plate - 883083726
Clutch Release Bearing Fork - 95011608606
TO Bearing Kit - 101518086
Clutch Release Bearing - 95011608008
EXHAUST
Replaced Primary Muffler with Cup Pipe FVD 170111044
Delete Cat
BRAKES
FVD Stainless Brake Lines B6435594
SUSPENSION
21 mm rear sway-bar - 96433370107 + (2) 4774113130
FVD Front Strut Brace - 115500337
MO30 ROW Coils 96534353101504/96533353103504
Bilstein HD Shocks Front-VE3-5277-HO(L) / VE3-5278-H(R) & Rear B46-01547
BODY - EXTERIOR
Removed Bumperets - Installed Turn signal Reflectors
INTERIOR - Other
Focal Solid 4 amp & Focal 165 VR3 (3-way) speakers
ELECTRICAL
H-4 Conversion Kit with Oshram Silverstar
High / Low beam bridge 96461018302
Divider Network
TRANSMISSION
EXHAUST
Delete Cat
BRAKES
SUSPENSION
BODY - EXTERIOR
INTERIOR - Other
ELECTRICAL
#40
1 Post
Bumping an old thread...
After 7 months of ownership, mine is still bone stock. Including the cassette holder!
Do I get a prize?![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
(Disclaimer: Except that the undertray is off for summer, and one of the POs has placed a small "Ballistic" sticker on the rear window
However, I am lusting after a set of Cup 1s. And lowering springs. And a primary bypass. And perhaps a chip.![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
It's kinda funny that the temptation to mod is almost a daily struggle with me. The main influences keeping me stock are 1) the bank account and 2) the Wife Approval Factor!
As time passes, I guess it'll become rarer to find the completely stock ones, they just seem so amenable to "personalisation"!
Do I get a prize?
#41
Bone stock except for H&R Greens + Bilstein HD + Strut Brace + larger rear swaybar + 17" Cup I's
#42
Mine is pretty stock and original including the rally car ride hight. I even still have the stock D90s although it fitted with 996 Cup wheels at the moment. Oh yeah did the cassette holder delete.
I do plan on Billstein HDs and H&R springs, maybe a rear bar, but otherwise I plan on keeping her pretty much stock. I have been debating on the H4s but been told that the H5s are plenty good enough. Maybe a mild brake upgrade with rotors and pads. I wont even do the LWF, and have a Luk replacement DMF for when the time comes.
I thought about getting all crazy with a 3.8 RS cams and Kompressor, but I don't think I want to do it to this car.
#44
I suppose the question is, how do you enjoy the car as is? If the answer is "I love it", then leave it alone and enjoy.
These cars were not delivered to the Euro zone, like they were here. Porsche intended for these cars to sit lower and to be enjoyed closer to the edge. It took me 2 years to collect the parts I wanted to mod the car with and to undertake the work. It's an expensive process both in terms of time & $'s, more than you will budget for.
If you have a wife that looks over your shoulder and asks questions, do yourself a big favor and leave the car as is.
#45
That is what keeps me stock. I have modfied cars before and by and large the modification have runied the car for anything but the track.
