Dyno figures
The issues are in your mind. Not in any engine dyno. Yet they, engine dynos, are true.
Second, why do you think there is a new SAE certification test process (J2723) available where the Corvette Z06 was the first engine to be certified using the process? It exists because regardless of what you dyno you use, you need to have a consistent test process.
Thrid, I can manipulate an engine dyno result by the following ways:
- Use different correction factors - SAE J1995, SAE J1349, SAE J2723, BS 5514, ISO 3046, BS AU 141, DIN 70020, Standard Temperature & Pressure
- Lower the barometric pressure input by putting a vacuum pump on the probe
- Raise the intake air temperature by putting the probe next to the exhaust
- Remove all of the accessory belt drives
- Running the test when the engine is below normal operating temperature
- Altering the calibration of the engine dyno
You seem to think that every engine dyno produces a "true" number and that cannot be further from the truth. And that every chassis dyno is useless which is also far from the truth.
I do agree that dyno numbers on Rennlist are all over the board and are meaningless when compared against each other. Do I know what the drivetrain loss is on a 964? No. Do I know what some engines I've tested show on an engine dyno and then again tested on my chassis dyno - Yes. Can I make an inference as to the loss between the two that would be applicable to just that scenario? Yes.
Originally Posted by Tom W
You can measure the drivetrain loss on the newer dynos... Mine shows about a 12 hp loss at 100 mph (where I get about 275 rwhp).
Some chassis dynos claim to measure, or calculate, flywheel power, but they are estimations at best, IMO.
Noah: Those were general numbers from the 3 engines I know the results for (on the two different dynos). My results were 295 at the flywheel on an engine dyno and 278 at the rear wheels (about a 6% loss).
VF: I agree that the frictional loss could be different, it's a question of how much different. While it's a stretch to compare results from different dynos, the 12 hp loss at a point where the "on power" figure is about 260 hp (12/260=5%) is in resonable agreement with the 278/295= 6% difference.
I provided my numbers as an alternative to the 12-20% numbers that get thrown around. Dyno numbers are fun to look at and great to use as an excuse for why you might be slower than another guy or gal, but not much help unless you can make the direct comparison. In my case, the shop that supports my car has built 6-8 engines for my race class. They all make about the same on the shops engine dyno. We all make about the same power on the same chassis dyno. That's a good enough comparison for me. What matters to me is when the engine gets built with different components and one of my competitors starts making 4% or 10 hp more power. When you are only 0.1 second apart on lap times, that starts to be something to worry about.
I'm an old engine on dyno type of guy, it was my bread and butter, albeit 4000BHP or so, but as long as the environmentals are the same, there is little if any opportunity to defraud Joe public. Whereas many's the time we all see huge gains quoted, and none of us have any certainty about the relaity of it all, unless of course everyone is playing by the rules of SAE J2723..
Kevin
i find it very difficult to believe that some of you guys are getting only 6% loss in power between the crank and the wheels. the problem is the fact there are so many optimistic dynos out there. We have six in our area and only one that we trust to give good enough reading.
