Oil leak (and need PET help) UPDATE: Leak found added pictures
#46
oil hose thermostat to tank 964 207 241 06 fig 104-01 #21
oil hose thermostat to tank 964 207 251 03 fig 104-01 #22
oil hose tank to body 964 207 217 00 fig 104-01 #26
connecting piece tank to body 964 207 130 02 fig 104-01 #30
and the washers which I can't get as my pdfs won't open.
#47
IMO do not consider anything but a hose from a Porsche dealer, Sunset or reputable parts place like Pelican.
Some have had this pipe/hose rebuilt by a local shop, however there has not been 100% success rate at that. When I did mine it turned out that the rubber flex connection point would rotate at the clamping position. Thus there was no way an independent shop could properly orientate the rubber to the pipe correctly. Even when the pipe does not rotate, the local shops may not get it done correctly.
Here in the Detroit area there are businesses that routinely make hydraulic hose rated to 5000 psi. The 70 psi of oil that our cars push through that -16 hose is really no big deal if a hose is made by knowledgeable people. I work in manufacturing so I was able to make my hose at work.
Basically, what we're looking at here is a AN-16 hose and DIN spec ends.
When I made my line I was able to source the crimp collars from Cohline, who is the O.E.M. for Porsche. I used the long pipe fitting from the old line, some new crimp collars and hose and a new straight fitting at the feed end (Turbos don't have the 45 degree fitting that the C2/4's do). I used the same final crimp dimension of the collars that Cohline used for our cars and had it crimped.
If the line you had made was swiveling then it wasn't crimped down to the proper diameter.
#49
Professor of Pending Projects
Great thread! It turned out that the source of my leak was coming from the washer on the oil filter mount too.
Does anyone know how/where to source the adapter fittings on the oil filter mount? Are they the same as the thermostat fittings? #43 in the PET diagram on the first page of the thread pn# 900.915.008.09 ?
Mine are sorely corroded and I do need to replaced some of those lines as preventative maintenance.
![](http://forums.rennlist.com/upload/hose_adapter.jpg)
#56
My 964 got oil leak on passenger side on part #1 and #2 (two flexible oil hoses). I went to hydraulic shop and got them replaced with new flexible oil hose crimped. It only cost $104 total.
#57
IHI KING!
#58
Thanks guy's just found this on the search on Google and has helped me no end on the n-gt after a my return from Spa and Nurburgring and getting oil leak
#59
Found today a small oil leak at the oil filter drain bolt in the right rear wheel well. Wachoko was talking about removing the plastic wheel well cover. Mine is missing I guess. Somebody a partnr ? Thanks.
