964 Forum 1989-1994
Oil leak (and need PET help) UPDATE: Leak found added pictures
Old 03-10-2009, 05:32 PM
elbeee964
elbeee964's Avatar
Jaime,
How'd you get your thermostat so spotless? (as shown in that last picture)
The short, stubbie hoses are obvious, easy replacement priorities:
PET No.....Part No.
30........964.207.130.01
26........964.207.217.00
21........964.207.241.01, .03, or .05
22........964.207.251.01, or .03
These three -- are they worth preemptively tossing?
31........964.207.143.00, or .01
41........964.207.315.00 '89,90 / 964.207.316.00 for '91 & on
37........964.207145.01
Old 03-10-2009, 05:33 PM
Kahdmus
Kahdmus's Avatar
Steve -- good advice thanks I'll make doubly sure although it appears that it is right at the connection as the rest of the hose looks bone dry at first appearance - I'll check it.
Jaime -- that's not part of you poking out of your car I hope!!! (if so, at least protection was being used....) It appears that the leak is at the top connection, is N.013.813.2 for the top washer?
Thanks,
--H
Old 03-10-2009, 05:34 PM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Thumbs up
Originally Posted by stevepaa
That liong oil line can also begin to seep oil through the rubber hose section and then flow towards the connections and make you think it is the connection. Try to clean it very well and then discover where the leak is really starting from.
To clean the thermostat, use simple green and a toothbursh and rinse with water.
Very good point. In my case, it was ready to be replaced:
Livefreeandrive
Livefreeandrive's Avatar
That is SO helpful thanks! I love this place! especially now that i have an older car that needs tlc! OK, how does that body molding on the side/skirt thing come off?
Old 03-10-2009, 05:41 PM
Kahdmus
Kahdmus's Avatar
Wow, the replacement oil line is $300!!! Holy cow!
Old 03-10-2009, 05:46 PM
elbeee964
elbeee964's Avatar
Originally Posted by Kahdmus
$300!!! Holy cow!
(Or, to quote Lightning McQueen: "Holy Porsche...")
Old 03-10-2009, 05:47 PM
Wachuko
Wachuko's Avatar
Cool
Be sure to have some epoxy glue and new clips (#4) handy... you have three of those clips that have plastic nuts inside the fender (use a 10mm wrench to get them out). Keep an eye on a metal piece that will fall out (clamping metal #19).
You have a phillips bolt that also needs to come out (#18 and #11). Loosen #14 or take it out completly, your choice. The sill will come out, back first and the the part inside the long side sill. If this has been in your car for eternity... the rubber strip will be dry, hard as a rock, has shrunk, and maybe one with the car... get a new one to replace it (#6)...
Old 03-10-2009, 05:48 PM
Kahdmus
Kahdmus's Avatar
Washers ordered...we'll go the cheapest route first! :P
Jaime, thanks again.
Wachuko
Wachuko's Avatar
Talking
Thanks,
--H
feeling is not the same with protection... so I put them to good use in the car...
Old 03-10-2009, 05:52 PM
Wachuko
Wachuko's Avatar
Shop around (Sunset, Pelican)... I ended up buying from both... for one line Pelican had the best price... by a long stretch... but for the other one, Sunset could not be beat...
Crystal Cranks
Crystal Cranks's Avatar
Originally Posted by Wachuko
Based on that description... take the passenger rear wheel out and remove the plastic wheel well cover.
What are these mysterious plastic wheel well covers you speak of?
My car does not have them are they only on later cars or only in some areas?
Old 03-10-2009, 05:59 PM
Wachuko
Wachuko's Avatar
Cool
This one... maybe widebody only cars have them... not sure...
Old 03-10-2009, 08:05 PM
Kahdmus
Kahdmus's Avatar
I have no wheel liners on the rear wheel arches.
Jaime, again, just to be clear, part# N.013.813.2 for the top washer?
Old 03-10-2009, 08:20 PM
Wachuko
Wachuko's Avatar
Cool
Kahdmus,
for the oil filter drain plug it is part # N.013.813.2 (US$1.00 from Pelican, less from the local dealer if you have a good relationship with them and/or PCA membership)
for the hose adapters (you will need two, one for each line/adapter) is part # 900.123.139.30 (US$2.00 from Pelican, less from the local dealer if you have a good relationship with them and/or PCA membership)
TexasPorschelover (06-15-2020)
Old 03-10-2009, 09:01 PM
911URGE
911URGE's Avatar
That long oil line can also begin to seep oil through the rubber hose section and then flow towards the connections and make you think it is the connection. Try to clean it very well and then discover where the leak is really starting from.
+1 Here is what to watch for on the long oil line. Note the how the hose changes color at the dry point.
Quick Reply: Oil leak (and need PET help) UPDATE: Leak found added pictures
