Daylight Running Lights
Is it difficult to convert the 964 to have daylight running lights? There is a place for a relay in the front fuse box, however I am not sure it is wired. Has anyone tried this?
Here are a few RL links searching for DRL (Daytime Running Lights)
https://rennlist.com/forums/964-foru...?highlight=DRL
We added a relay into the spot in the panel which is reserved for a Daytime Running Light relay, but which in your car will be blank - it is R63. We actually went to an auto wrecker and got a relay from a 90 vintage Passat. The relay is purple and the part # is: VWAudi 431 951 253G -- there is also another set of #'s on the relay: V23124-B52-X372. We simply added that relay and our daytime running lights were in working order!
Cheers.
Dave - if the headlights are off, the "running lamps" or fog lights are on. If the headlights go on, the fog lights go off. If the headlights are on, you turn on the fogs by pulling the dash switch to turn them on. I have the lamps on... you can see in my avatar pic. Just required plugging in a relay.
i'm tempted to do something with mine, just not sure what, i dont have my fogs fitted... maybe some neonz lol - seriously though, tempted to either refit fogs, or put something in the indicator lense. then move the indicator around to the side... or put something in the side.
or just not bother
or just not bother
As I am in Canada, my fog lights are my DRL. What I would like to do, is replace my fog lights with brake cooling ducts, and then somehow hook up low beams as DRL. Any suggestions on how to do that.
I found the Bosch part # 0332014134 from a web supplier for $9.95USD. Works great. I like the having a little more visibility on the road with all those SUV's.
I wonder if there are any other cool features that require very little work. I put the bulb in the oil temp guage and have the green light come on when the PDAS system engages. I guess I am amused by little things.
