964 Forum 1989-1994
Starter problems?
Old Feb 23, 2009 | 10:24 AM
hans57's Avatar
hans57
Question Starter problems?
I have a question,
I have what seems to be a developing problem with my starter on my '91 C2 cab.
It cranks and starts fine first start of the day every time, but sometimes when it is warmed up I have this issue. While cranking, just before the motor starts it will suddenly stop as if I released the key. I will then crank again and it will be fine, starting the engine. Does not do it all the time, but maybe once out of three or four warm starts. Is this a classic sign that it is going bad? Can it be replaced with the engine in the car?
Thanks in advance for your input.
Old Feb 23, 2009 | 11:20 AM
Wachuko's Avatar
Wachuko
Professor of Pending Projects
I know I repeat this everytime I see a starter-problem thread but I would hate you having to spend the cash and hassel to replace a starter if the problem is with the cables.
Check your starter positive and negative cable. The end that attaches to the stater. The treads of wires inside the terminal break. As the positive cable treads break you experience problems starting the car as not all the amp/juice from the battery is getting to the starter.
The solution is to strip the cable and clamp a new terminal in place.
Also disconnect and clean the end that goes to the battery. And fully charge the battery.
Check/do that first before you take any other steps.
Old Feb 23, 2009 | 11:29 AM
crg53's Avatar
crg53
+ 1 to What Wachoko said. But in addition, I had exactly the same symptoms, starts fine when cold, occasional problem when warm, and it was the starter motor going bad. My car is a C2, and changing the starter motor is not that big a deal if you have the right tools, lots of information here on that subject.
Cheers
Old Feb 23, 2009 | 11:59 AM
Indycam's Avatar
Indycam
Could be the in dash ignition switch .
http://www.carparts.com/REMOTE-START...9_N__10618.car
Old Feb 23, 2009 | 12:10 PM
elbeee964's Avatar
elbeee964
Jaime's just being the 'Good cop'.
Now -- my Bad cop: Unless replaced before, your starter likely needs replacing. Sorry.
But, HEY! Cheer up! We've got LOTS of forum posts & guidance on the topic!
Old Feb 23, 2009 | 02:42 PM
Wachuko's Avatar
Wachuko
Question
Was this ever an issue with the 964? Let me check part number. I know it is a common issue with 944.
That link to the tool looks like something to add to the toolbox. For the price it makes no sense to build it myself.
Old Feb 23, 2009 | 03:12 PM
Indycam's Avatar
Indycam
Was it ever an issue ?
Switches go bad . No switch lasts forever . They will all fail at some point .
Perfection is perfectly impossible .
The tool in the link might not be one you would care to own .
It might be junk from the get go .
Don't buy it just cause I linked to it please .
Old Feb 23, 2009 | 03:16 PM
Wachuko's Avatar
Wachuko
Cool
True, just asking if it was a common issue in our cars like it was for the 944 and for the 996. Anything can go bad and that could be one source for the problem.
No worries... just looked like a good tool to add, but looking at the wire gauge, that thing would fry the first time is used in a car... just looking to an alternative to the screwdriver jump
Old Feb 23, 2009 | 03:21 PM
Indycam's Avatar
Indycam
The amperage to the solenoid coil is small .
You are thinking of the switch going on the battery wire .
It does not go on the battery wire .
You use the switch to power up the solenoid and the solenoid connects the big battery wire to the starter motor .
Old Feb 23, 2009 | 03:27 PM
Wachuko's Avatar
Wachuko
Exclamation
Duh Jaime! Thank you Indycam! For some stupid reason I went back to the days working in my dad's trucks... old F350s... I would see the mechanic we had using a screwdriver to test the starter... never clicked, until now, on the CORRECT way of doing it...
Old Feb 23, 2009 | 03:32 PM
Indycam's Avatar
Indycam
The big *** sparks from doing it the manly way are so much fun !
Old Feb 23, 2009 | 03:37 PM
Indycam's Avatar
Indycam
The solenoid went bad on my old vw van , I did the jump the solenoid posts with a wrench trick a few times to get the motor to run .
Get in , turn on the switch , put it in neutral , check the hand brake two times , get out crawl under and jump the posts . Hope like crazy that the van does not run me over ...
Old Feb 23, 2009 | 04:17 PM
hawk911's Avatar
hawk911
Sounds like mine when it went- the starter that is. Just make sure if you buy from pelican that you plan on replcing it soon- 90 days to return the core. Anyone need a 964 starter core?
Old Feb 23, 2009 | 04:39 PM
Indycam's Avatar
Indycam
They screwed you on the core ?
They said you did not return the broken part in time ?
I hate that sort of S..t !
How has that done them any harm ?
Old Feb 23, 2009 | 08:50 PM
hans57's Avatar
hans57
Sounds like a plan, I will do that. Stands to reason too because it only acts up when it is warm/hot after driving.
Thanks!
