964 Forum 1989-1994
My rear fan bypass box!
Old 03-24-2009, 05:09 PM
  #46
MPB993
MPB993's Avatar
yep, sorry meant early 964 and not early 964s :-) My ccu nos is 993 659 048 01
Old 03-24-2009, 05:37 PM
  #47
rollingjack
rollingjack's Avatar
As I understand pin G19 by CCU is connected with rear blower relay socket pin 87.
We have jumpered 87 to 30.
G19 by CCU must have 12V now.
Old 03-24-2009, 05:42 PM
  #48
MPB993
MPB993's Avatar
Rolling jack
that is correct. On 993 rear blower relay socket pin 30 is connected to +12v via a 30A fuse which I reduced to 1A just for safety sake. pin 87 goes to pin G19 & G1 on ccu.
BR, Mark
Old 03-25-2009, 12:30 AM
  #49
Jeff Curtis
Jeff Curtis's Avatar
My car is a November '90 build, but it is a 1991 model...the jumpers worked PERFECTLY and right on time with that info. Rolling Jack as I was about to solder in the resistors today!
FWIW, the wires do not get hot...I had everything running for about 20min. and went for a (VERY NOISEY) drive, no problem.
Noisey due to the new semi-solid motor mounts and solid trans. mount - UGH.
Old 03-25-2009, 01:02 PM
  #50
Livefreeandrive
Livefreeandrive's Avatar
Ok, I am guessing that the 35 pin harness is connected to the back of the CCU? My Bentley book suggests connecting G1 and G19 if you upgrade CCU?
What is the rear fan supposed to do with CCU switchs in off position?
Mine cycles on and off all the time so is this the problem we are trying to solve? I am not interested in eliminating the rear fan
THANKS!!!
Steve
Old 03-26-2009, 06:21 AM
  #51
Duck
Duck's Avatar
I would think you can get the Y or T adaptors at most auto supply stores.
Old 03-26-2009, 08:31 AM
  #52
GP White
GP White's Avatar
If you use a T fitting, make the straight flow go to the distributor.
Alternative is to drill another hole in the CF tube and fit a second tube connection. IIRC the recommended procedure for this was discussed on this board.
Old 03-26-2009, 09:22 AM
  #53
ThomasC2
ThomasC2's Avatar
That's why you should by the factory parts, it has 2 connections ;-)
Old 03-26-2009, 11:11 AM
  #54
Mark J
Trial Rennlist
Mark J's Avatar
can you not drill a second hole in the Fabspeed part ala the factory part ? ie same spacing and diameter.
Old 03-26-2009, 11:44 AM
  #55
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Mine did not - I added the breather kit by drilling a hole (Oh yeah, Porsche is not perfect..... ).
Marc
Old 03-26-2009, 11:46 AM
  #56
Marc Shaw
Marc Shaw's Avatar
Yes, that would be the easy answer but I wanted the same nice aluminum breather nipple the Fabspeed one has.
Marc
Old 03-26-2009, 10:27 PM
  #57
xeps
xeps's Avatar
I gave the double jumper trick a try this afternoon in my 89 C4, works perfectly. I have the original CCU, and was previously unable to get air unless it was set on full cold.
I didn't have any appropriate fittings, so I just used some 14awg stranded wire - smashed it flat, and dropped a touch of solder on the ends. Ugly, but gets the job done for the time being.
Old 03-26-2009, 10:52 PM
  #58
doug751
doug751's Avatar
Anybody have the part number for the OEM bypass tube?
Old 03-27-2009, 03:01 AM
  #59
Duck
Duck's Avatar
Old 03-27-2009, 04:25 AM
  #60
ThomasC2
ThomasC2's Avatar
Good to hear that it seems to work for everyone, regardless of MY. And it's still only I who have the hesitation on fan speed 4....strange!
Quick Reply: My rear fan bypass box!
