Front Hood Shocks Recommendation
I need new front hood shocks, shocker. Is there a preferred brand? According to advertising Weltmeister last longer than the OEM Stabilus. Is this true?
If it were your car what would you purchase and from where? A broom handle to prop it open is not the correct answer.
Sorry about the spelling on the last title.
You can do a search here for more info, but the Weltmeister ones I bought from Performance would not fit...there was too much metal on the end and as a result I couldn't get the shock end to fit between the ball and the fender metal. Performance told me I had the correct part number and wouldn't take them back.
Don't know if I got a mislabeled set or what, but I went with the Stabilus (from Pelican) and they work fine. At half the price, I think the Stabilus is the way to go. So what if they need replacing after 7 years?
Make sure you get an extra end clip in case one of yours shoots off into the yard...
Hey,
Pelican is where I purchased mine. Great webite,for tech tips too! I had a heck of a time with the driver side strut,do to the small space where the lower part of the strut fits and the clip removal, I couldn't see down into the space. I since have gotten a mechanics telescoping mirror. I look forward to finishing the job.
Frustrated mechanic wanna-be
Agent Orange
Hey,
My Pelican shocks are still fine front and rear after two years. No problems in winter.
Installation is no problem if you follow the DIY help available here. Several times I have wished for telescoping arms and fingers, but a 964 is a pleasure to work on compared to most modern cars.
Theres a company that makes new hood and trunk props. Made of carbon, a lot lighter than shocks, look good and dont wear out. Ill look for the link but saw it on that flat black 935 project on this forum
Agent Orange
The trunk prop costs around $40, a little more than hood shocks. You will need to drill the body to install it. It is also not recommended for steel hoods, since they are quite heavy.
