Crank Pulley Removal
I need to remove my crank pulley (engine in car) in order to remove the ac bracket to replace the timing chain cover. I have tool P9285/1 for removing the pulley, however I have not been able to get the P9290 tool in order to hold the crank in place to remove the holding nut. Anybody have any ideas on how to get the holding nut out with damaging the harmonic balancer. I have done a search and read where it is not good to put the car in gear as a way to hold it in place.
Thanks.
Thanks.
you want to do this with the engine in the car? not sure that is wise. first you don't have a lot of room in that situation, second you can't see what you are doing very well. you wouldn't want to cost yourself a ton of money causing damage because you couldn't see what you were doing. in my view you have to pull the engine. if we lived closer I'd come by and walk you through what to do. in the absense of that I'd recommend you consider calling Bob Aines shop in Charlotte.
I already have almost everything off the back of the car (engine tin, rear bumper, engine carrier, etc.). Therefore I have fairly good visibility. The problem will be holding the pulley in place to loosen the bolt (even if I had the engine out of the car). I can get the P9290, but it will take 3 weeks. I was hoping there was another option someone has found (since I doubt many have the P9290).
Thanks.
Thanks.
Can you not put it in gear + handbrake to lock the crank? BIG Screwdriver through an access hole in the gearbox and pressed against a tooth in the ring gear?
With the engine out you can use a bar on the flywheel end locked against 2 temporary long flywheel bolts.
if your just going to remove to provide clearance to remove a/c bracket you can remove the 10 or so small bolts without disturbing the main center hub. just make sure you mark the pully to the hub so you can put it back on the same way. also there are shims and what not when it comes loose so pay attension to the way it comes apart. when you reinstall the small bolts i belive there is 10 or so, use locktite blue- medium strenght, do not use the red high strenghth.
to make life easier, get a piece of cardboard and number the bolts and poke holes in the cardboard and push the small bolts thru as you remove them so you can put them back the same way if you want it to be perfect. make sense, get the card board and draw a circle and if there are 10 bolts , poke 10 holes.
also when you remove the first bolt you can get a piece of string and run it thru the front of the pulley and tie a knot on the front and back side and this will be a foolproof method to keep the parts in the correct orientation.
i am not trying to insult you and to my detailed discription, some people say if you are to detailed its like talking to a 5 year old, but i say if you do not how the hell is anyone going to understand what you mean.
i have done this before and its easy. you need more help, just buzz me, i will give you my number. i live in columbia, sc
Thanks dutchcrunch. That sounds like a good solution as I have read you do not want to put any force on the crank to loosen the bolt. Also I appreciate the ideas for getting back together correctly. I have a bad tendency to not be careful on the details of the removal and therefore sometimes run into problems on re-install. Therefore I will try what you have mentioned.
gecc - I tried to get the 9290. It is very steep cost ~ $200 and looking at 3+ weeks to get it brought in from Germany. No one seems to carry this anymore in the US.
Thanks.
Thanks.
Thanks Dutchcrunch. I took your advice on the 10 bolts and it worked perfectly. I tied a piece of old speaker wire through the first hole to keep everything lined up. I am thinking of grinding off the tabs on the ac bracket so that it will come off in the future without disturbing the crank pulley.
Thanks again.
Thanks again.
that was my plan to on an earlier job but I didn't dare to try in the end.
Did you just use a set of pliers or?
Thomas; I bought a set of stud extractors, the hextype with anti-clockwise internal flutes, and used these. There is not enough exposed thread to lock-nut them free. The extractors ruin the end of the studs, so I replaced mine with the same length high tensile studs, but with an internal hex socket in the end. Easy to remove in the future. Regards, Les.
Thanks again.
Thanks again.
