964 Forum 1989-1994
C4 guy's HELP
Old 12-04-2008 | 09:04 PM
Dwane's Avatar
Dwane
Default C4 guy's HELP
Does the light on the console for the 4 WD light up?
If so, I need to change the bulb!
thanks
Dwane
Old 12-04-2008 | 09:42 PM
dfinnegan's Avatar
dfinnegan
When I turn on my key, before starting the car, I have the (!), and the right hand two lights below it on (the green pdas light was added by me), and I have five of the lower lights on (lower left is off). This is on the oil temp/press gauge.
Old 12-04-2008 | 10:03 PM
tbennett017's Avatar
tbennett017
AFAIK, the green PDAS light does not light up as a stock item. It requires some sort of mod...?
Old 12-04-2008 | 10:14 PM
Dwane's Avatar
Dwane
Just to clarify... I am talking about console and not the dash.
thanks tbennett
Old 12-04-2008 | 11:19 PM
dfinnegan's Avatar
dfinnegan
Ah, the little yellow light in front of the shifter? That does light up. Though, it's a bit difficult to see it go. I do see mine at night hitting cross cuts in the road.
As for the green light, it is all wired and ready to go, but there was no bulb in it when it shipped from the factory. I simply purchased a bulb (something like $2), pulled the gauge, and installed the bulb. Some folks don't like the green light, but I find that it's interesting to be able to see when the system engages. I've had it light up on dry pavement blasting through the turns. I've also seen it in a straight line in low gears.
Old 12-04-2008 | 11:52 PM
DWS964's Avatar
DWS964
The small yellow light above the **** on the console should light up briefly as you turn the key to start the car. The diff locks go through a test, that you should be able to hear them click. Then, the light should come on if you turn the **** to manually activate the PDAS, and blink while activated. And finally, the light will come on any time the PDAS is being activated while driving - like when powering around that really cool s-curve on Bunker Hill Rd. on the way home from work. Make a game of it, to see how many times you can activate it during your commute.
Old 12-05-2008 | 01:13 AM
tbennett017
Yes, I like to play that little console light game too... I can just see it out of the corner of my eye as I take that uphill right-hander on the way home. Its when I feel the front inside wheel begin to hook up and pull. But now with my suspension drop, I don't see it nearly as often. I will have to try harder.
Old 12-05-2008 | 09:39 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
While driving, I will occasionally notice the light come on. If you want to test the light, you can manually engage the system by twisting the **** below. It will turn on the light. The system will disengage around 25mph.
Old 12-05-2008 | 11:50 PM
Dwane's Avatar
Dwane
Let me try this again...I am talking about the little diagrams on the console in front of the shifter. The one for the spoiler lights up green when I turn on the lights. The one that looks like a chassis doesn't.
thanks
Dwane
Old 12-06-2008 | 12:02 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Do you mean, these lights? The lights above the switches?
If yes, there is a good repair instructions John's 964 web. See http://www.porsche964.co.uk/technical/conslights.htm
Old 12-06-2008 | 02:55 PM
Dwane's Avatar
Dwane
No, The one that looks like a chassis, next to the spoiler diagram.(above the right hand ****). Does it light up green like the spoiler diagram, When you turn on the lights?
Someone please HELP OUT!
Dwane
Old 12-06-2008 | 05:39 PM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Dwane - Is this the one?
If yes, it is back lit, when I turn on my headlights.
Old 12-06-2008 | 06:54 PM
user 783003's Avatar
user 783003
I checked this link out. There are two methods in that DIY, one where you cut the run in the PCB, use 3mm standard LED's install an in line resistor. The other method describes a RS part number LED with build in resistor and can be wired backwards (RS = Radio Shack?). The second method leaves the circuit board alone which suits me better. However, I went to RS and could not find the RS LED (p/n - 283-0011).
Anyone else done this?
Old 12-07-2008 | 12:46 AM
Dwane's Avatar
Dwane
That's it!
Thanks guy's!
Dwane
Old 12-07-2008 | 12:54 PM
elbeee964's Avatar
elbeee964
Yes, I did. Kind of. (RS = Radio Shack)
I didn't find the listed LED's in my RS's LED drawer. Was looking for the clear, 12V LEDs for the upper three lights. Only found Red, 12V LEDs. Was impatient, decided not to wait for a special order (of the clear types) to come in, so bought and tried the Reds.
Worked fine. Love them. Will never burn out.
