smoke
smoke
Hey guys,
I've owned my 964 for 6 months now. Absolutely love it. My question is about smoke at startup. My car 93 C2 with 48K, smokes for about 30 seconds when starting cold. It never smokes while driving or idling nor does it smoke when starting hot. I guess its not that big of a deal other than it being somewhat embarrasing. When I bought the car, I was told by several Porsche people that a little smoke at start up was normal for these cars. How does that explain those that don't smoke at startup however....abnormal?
Anyways, is this a big deal or should I just deal with it? Is the only fix for this condition a top end rebuild?
Thanks in advance for all replies!
Derek
Derek
to be honest, i wouldnt worry, maybe get a leakdown test if you want to check, that will tell you the wear on the engine...
my 3.2 is still going strong, and making good power.
Have a smokey 964 at cold startup? I do!
Mine is a 964 Turbo as good as new because of the mileage is only 20.000 km. So I guess if mine smokes at startup now, it also did 16 years ago when it was complety new. Anyway, don't worry about this, it is normal. And I can promise you my car smokes a lot more than your car. So again, this is normal and don't worry about it!
Mine is a 91 with 84K and if I leave it for 2-3 weeks and start it up I get a tiny puff of smoke for 2-3 seconds and then it's gone... Never comes back unless i let the car sit for a really long period of time. Not sure why some would and some wouldnt ???
Rob
Rob
I used to get smoke on cold starts after extended no use, now what I do is, when I get home from a good run, let the car idle for a couple of minutes before you shot it down, gives you a chance to check the oil level, and no more smoke on cold starts. Give it a try.
ginch - Are you sure you dont have or had an oil overfill condition? Ive read that overfill conditions can lead to oil coating the intake system and then pooling into the cylinders causing the smoke at start. Of course oil can pool when sitting for long periods of time.
Thanks for the replies fellas. The car has definately not been overfilled so unfortunately thats not the issue. I guess maybe the Valve guides are worn. Seems premature though doesn't it on a 48K mile car? Also, as asked before, does changing the vavle guides require a full top end rebuild?
Derek
Derek
+1 Ilko on valve guides, or seals
With so few miles, might the car have sat for long periods when the O.E. composite valve seal material could have dried out and shrunk?
Either valve giude or seal replacement = top end rebuild. At least top end diassembly/reassembly, which common sense turns into a rebuild. "Gotta take it apart to get to it", although I've heard of some Gerry-rigged schemes where air pressure in the cylinder is used to hold the valve against the seat while the spring is removed for a seal-only replacement. However, if you've got a problem, I think you'll want to get in there to evaluate the situation.
Only reason I would be concerned is that, from what I understand, valves are cooled by their contact with the guides, which dissipates heat through the head. Worn guides can result in overheating of the valve stems and failure. I had a valve break and it is not pretty. I tried to upload the phot of the destroyed cylinder and head, with the valve head jammed edgeways into the valve port, but couldn't get it to work.
I think it is possible, from an experienced mechanic feeling the play between the valve and guide by rocking the valve back and forth, to estimate the wear. I would recommend a valve adjustment with a request that the mechanic check the guides in this manner, if your mechanic agrees to this test. I think it is possible??? to check this with the rocker foot backed off and the valve springs loaded.
Hope I'm not making too much of this.
Good luck.
Good luck.
