LSD rebuild question
Yes, a fully functional lsd will increase udersteer, the amount will depend on how the lsd is set up. The beauty of the 40/65 is that it doesn't induce too much understeer yet adds a lot to braking performance
Anyway, it may well be that your LSD's friction discs are shot, but it's certainly plausible that they are still good. Even though you can rotate the wheels by hand that still doesn't mean the friction discs have worn out, but rather you're getting a demonstration of the characteristic low preload spring rate on this LSD. I suspect that the only way you'll know for sure is to disassemble the LSD to see what's worn and in need of replacement.
In the final analysis, the 40/40 LSD is still a good to excellent choice for a C2 964 that's driven mostly street, occasional track. It may well not be the best however. The 40/65 993 unit mentioned by Bill Verburg is probably better, and certainly is so on a theoretical basis, because it offers far more lockup capability on the deceleration side of the equation. However, having said that, it may be too good on the acceleration side for your 964. Because it's a 4 friction plate LSD, it will work REAL DAMN GOOD and you'll get tons of torque transfer from one driving wheel to the other. I'm already trying to cope with more torque transfer than I can handle with the 2 disc 40/40 unit, so I don't know how I'd cope with even more potential front end "push". Perhaps there's someone out there that's installed the 993 40/65 LSD in a non-racecar 964 that will share their experience and perspective?
I'm not sure if the ring and pinion will need to be re-set post diff rebuild - I didnt re-set mine when I pulled the diff to get at a seal that had been pushed in too far and all has been fine since.
1) While it is ok to drive it on the street with a worn out clutch pack in the LSD, is there any risk driving it on the track this way? I have a track event coming up in less than 2 weeks. Problems with handling?
2) Would a worn out clutch pack in the LSD explain the symptom I described where if I'm driving at 70 on the highway in a straight line and mash the gas pedal to the floor, the car seems to pull slightly to the right? Kind of like torque steer.
No, not likely to have an issue on the track either. Unless the disk cracks which I've not seen
they can rebuild w/ better than oem friction disks
There has long been speculation that the sloughed off friction material from our LSD, as well as pretty much any LSD, factory included, could accelerate the wear on other components inside of the gearbox. This is part of why we tell people to do the following:
1. After initial break in of 500-1000 miles or so change your gearbox oil after installing our LSD or getting yours rebuilt. When you buy a new car, you do an initial engine oil change at an abbreviated service interval. You should do the same with our, or any new LSD you put into your gearbox.
2. Change your gear oil at a maximum of once a year. I don't know what Paul used to tell people as a mileage for service interval, but I suggest 10-15k miles. These are high performance cars that get beat on. Guys change their engine oil at 2000-2500 miles against published factory service intervals of 3000-5000 miles, but they never seem to think that they should change their gearbox oil more frequently when they drive their cars sportingly. I change my own gear oil every 6 months on all my cars because in all honest I rarely make it to a year because of #3.
3. Change your gear oil after every single race. If you "just" go to track days and run hot laps you can probably push it out to 2-3 track days/test-n-tunes. I personally mostly do casual track days and don't race much outside of auto-x and rally-x. But if you drive the car in a racing environment at it's mechanical limits for an hour or more, it's cheap insurance to spend $50-100 on gear oil.
These are things I have been telling people for years and not just something I say now that I have a vested interest in the performance and longevity of your gearboxes. I am sincerely sorry to hear when anyone suffers a premature failure on a gearbox. And if anyone ever has a problem with a gearbox that they believe is related to one of our products, please let me know. Just be warned that I don't just hand out checks or replacement parts. If a product that I sold fails you, I'm going to want the whole gearbox shipped to me and to be able to assess it with my own technician. I don't mess around when it comes to product quality. I'm not going to pretend that what we make and sell is perfect and even though like most motorsports parts manufacturers we've got that little note on our invoices that says these parts are for racing and carry no warranty expressed or implied, the fact of the matter is if something is defective I'm going to stand behind it. There is that old adage of "that's racing" but if there's a flaw in something I am putting out there it's my intention to correct it and make it better. This is my livelihood we're talking about here. We're not some major corporation with deep pockets and multimillion dollar budgets. If there's a problem, it's in my best interest to fix it and fix it quickly. When you call us, you get me or you get my wife. That's it. That's the business, and if we don't do right by the brand that Paul Guard spent the last 20 years building and refining, then we don't deserve to be the caretakers of the name.
Regards,
Matt Monson
Guard Transmission LLC
303-530-1094
