Poser.....
Here's a few pics and measurements of the prop.
The overall length is 431mm.
Rod diameter is 8mm.
The length of the taper on the end is 12mm.
The hole is 7mm dia.
As you can see the end is flattened out for approx 22mm.
If you lay the prop flat on a table; from the table to the bottom of the flattened part is 5mm.
part 2 on the way
Part 2:
The mounting plate is 1mm thick and 62mm X 27mm.
You can see that the plate is curved on one side (long side) to fit neatly.
The threaded stud is 6mm metric with a nyloc nut.
The stud is 15mm long.
The holes are spaced 42mm apart (long ways) and 11mm apart (across) and are 3.2mm suitable for 1/8 pop rivets.
Sorry I have no details of the clip that hold it when not in use.
I hope this helps those that want to make there own.
You can see the part number on it so check it out at your local stealer. You may be surprised
Nice, I see that you chose the "old school" hood pins from the correct decade, at least if you want the CUP-look. I haven't decided what to do yet...go for the correct ones as you have done or buy the more modern Motorsport pins (round ones with a red pin), which I think look better.
All these tough decisions....it makes my head ache!
I'll help make it easier. The later style are a pain because you have the pins dangling all the time and they contact the painted surface which then scratches or pits them. They are also expensive compared to the old style.
Here is a pretty cool link to a Duc HyperMotard 1100 vid. If you like bikes the are several very well done vids that make me want to go ridin every time I watch.
http://www.drsardonicus.com/
