964 Forum 1989-1994
HELP!! Hood release not working
Old 08-15-2008, 02:56 AM
  #31
elbeee964
elbeee964's Avatar
The engine hood's route isn't as obvious or straightforward as the front hood, that's for sure.
It's late here, and I couldn't find any pertinent pics.
If I don't see someone pop in with the goods then I'll snap some Friday eve, Sat.
At the time I didn't drop any bumper pieces, so had to fish the line blind for a little of it's travels. (Believe I used a coat hanger to guide the way? ie, like the front there's not guide pipe to route it -- you just pick your points...) No doubt removal of that center (red-pink!) lens would'a made the job easier...
Old 08-15-2008, 08:53 AM
  #32
ilko
Agent Orange
ilko's Avatar
The engine secondary release cable is located inside the driver side tail light socket. Much easier to install than the front hood IMO.
Old 08-15-2008, 09:33 AM
  #33
elbeee964
elbeee964's Avatar
What? This emergency cord routing isn't clear (as mud) to you?
Name:  rear instructions.jpg
Old 08-15-2008, 09:50 AM
  #34
ilko
Agent Orange
ilko's Avatar
Want clear? Here's clear: http://www.rsamerica.net/articles/te...id_article.htm
Old 08-15-2008, 09:58 AM
  #35
elbeee964
elbeee964's Avatar
Sorry, Ilk -- left my Superman x-ray vision at home.
And, well, there's a wee bit of sheet metal there obscuring that cable route path...
But the "big picture's" clear!
Old 08-15-2008, 10:04 AM
  #36
ilko
Agent Orange
ilko's Avatar
I'm actually going to be working in that area today (installing a 5 brake light mod in the center reflector), so I can take more pictures if you guys are interested.
Old 08-15-2008, 10:29 AM
  #37
Wachuko
Professor of Pending Projects
Wachuko's Avatar
This thread really comes handy. Chet's car just suffered this issue. We wil tackle opening the hood tonight. And I will make sure we put a backup cable in both cars!
Thank you as always for sharing!!!
Old 08-15-2008, 11:18 AM
  #38
ilko
Agent Orange
ilko's Avatar
Here's some pics from the rear...
(yes my car is dirty )
Old 08-15-2008, 11:50 AM
  #39
elbeee964
elbeee964's Avatar
Ilk (or, anyone), what's the take down method for that center lens?
Wish I'd known about that. Negotiating that little 3/8" dia hole "in the blind" because of that center lens was a hindering PITA.
Old 08-15-2008, 12:11 PM
  #40
canuck964
canuck964's Avatar
Can anyone confirm that the rear cover emergency release is available for all years 89 & onward 964's?
Old 08-15-2008, 01:07 PM
  #41
ilko
Agent Orange
ilko's Avatar
Lonnie, my center lens is broken and is only held by the three screws at the top. It was broken on my old 964 as well, so I guess it's a common thing. I believe there are tabs at the bottom of the lens that you can wiggle out and set it free
The emergency cable was available only on 92+ cars and not on all of them AFAIK.
Old 08-15-2008, 01:26 PM
  #42
Kahdmus
Kahdmus's Avatar
Well documented for the boot/trunk cable but thats a definite for the REAR lid as well?
Old 08-15-2008, 02:48 PM
  #43
ilko
Agent Orange
ilko's Avatar
I've learned to not take anything from Porsche as a definite
Old 08-16-2008, 08:37 AM
  #44
elbeee964
elbeee964's Avatar
Looks a lot like yours, Ilk.
The tail overview shot shows there's no twin passage hole on the right side.
(Guess that little 1/2-3/8" hole is meant to be just for this emergency lanyard.)
There's yellow tape on my end loop because I'd seen other lanyards rub paint raw at the loop end.
Only a precautionary measure I did at the time.
Haven't looked here in over a year -- seems to be holding up.
Old 08-16-2008, 08:58 AM
  #45
Computamedic
Computamedic's Avatar
It's worth noting that the catch mechanism used on the pre-92 cars is very different, using a notched pillar which drops into a circular latch. On this early design the release of tension in the cable (i.e. when it breaks) fully releases the catch so there is no purpose for an emergency release cable.
I had my cable break (actually I broke the handle trying to straighten it!!) and the engine cover popped open on it's own as I was driving along. The replacment cable, handle and grommet came to less than $40 from the OPC.
Regards
Dave
Quick Reply: HELP!! Hood release not working
