OT: My new garage build
#61
Super Duper Moderator
Well, I now have a floor with piping for in-floor heat and 10" thick 2-post lift pads.
Electrical wiring started today too.
Marc
Marc
#62
#63
Marc
Not sure what the rules are there but here in Ontario code says AC outlets have to be 4' off the ground minimum in a garage. Those outlets (i.e. if they're AC) at the bottom look a little low but maybe the fact that one could probably live in your garage negates this fact?
Bill
Bill
#64
Marc
Bill
Bill
18" min in AB so the uppers are at 4' while the lowers are at 2'
Marc
#67
Yup, lots of progress.
Roofing is done, the stairs are in, the wiring, and the insulation are done (the gap in the back wall is for an exhaust fan), and the wallboard (5/8" sheetrock) is started. Siding is going on the outside and the OHD is on order to be installed (hopefully) later this week.
There is blocking in the walls for a large screen TV and air/electrical lines. Wires from the ceiling are for lights, ceiling fans, and speakers.
Marc
Marc
#71
Finally -- Shingles! Siding, Windows. ("-- come on, thunderstorms!")
Insulation! ("-- come on, Fall!")
Now things can proceed at your discretion, not the weather's. Nice.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
So, Marc -- you've got a pile of dirt, now, in the back yard.
You gonna throw some seed on it and call it an 'ornamental landscaping addition'?
[what I'd probably do. gag-name it, Mt. Porsche, or the like.]
#72
Thanks for the compliments - I am happy it is coming together well, if not slowly.
The dirt pile will be flattened to build up our lot and we'll assemble a swing-set for my 5 year old.
Marc
#73
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
I thought about it but figured it would be a pest if I managed to clog it and the pipes were inside the walls so I plan to get one of these. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Marc
Marc
http://www.amazon.com/gp/product/B000289920
And your garage is coming along great!!
#74
A few more update pictures:
-exhaust fan installed
-siding done
-wallboard on
-mudded & plastered
-painted
-most outlets done and speakers in the ceiling.
Waiting on front OHD (custom build), 6-bulb T5 lights (special order) as well as for the electrician to install the outside lights.
Next the plumber will hook up the water supply and setup the in floor heat.
Marc
-siding done
-wallboard on
-mudded & plastered
-painted
Marc
