Whining Noise; rt side of engine after belt change
Last week I paid a reputable Porsche shop to change my belts and oil (I know, I know...but I have just been too busy with work lately to do anything myself).
I now have a load whining noise from the right side of the engine. I can't seem to pinpoin its exact location. I don't remember ever hearing that noise before.
It is rpm dependent and the whine starts at about 2000 rpm, increasing in pitch as the rpm increases. Same noise whether the car is moving or stopped; same noise whether the AC is on or off.
The belt tensions seem proper to me, and the car only has 50k on it so I would be surprised if it was already an alternator or ps pump bearing. Any ideas?
cwrm4
Was the whining noise there before the belts were changed?
If not, and since you have limited time on your hands take it back to the shop.
If it was there before and youv'e lost faith in the shop and willing to do some diagnosis work, remove one belt at a time and see if the whinning goes away.
Hope this helps
Bill
90C2
Hope this helps
Bill
90C2
IHI KING!
I would double check that your power steering fluid reservoir is full. You may be hearing the power steering pump cavitating. Otherwise, I would take the car back to your mechanic.
cwrm4
The ps belt is a cogged belt and you may just be hearing the belt breaking in or if they opened the lines on the ps pump some air may have gotten in. In which case a couple full left/right stop to stop movements of the steering may purge the air of the system.
Hope this helps
Bill
90C2
Hope this helps
Bill
90C2
One more guess. After I had my belts changed a few months later my fan hub started going and that was a constant whir. You can check to see if there is any scoring on your fan housing at the bottom. You can search on fan hub and find my thread (I can't figure out how to quote from another thread or I would give it to you)
Check the belt tension sensor. As they age, they begin to whine. I've had mine off a couple of times to clean and oil. It works for a while. I've purchased a replacement ~$60, if I recall correctly, but haven't installed it yet. That expenditure seems to have quieted things down; of course.
Thanks for all the help...I did finally positively ID the PS pump as the source of the whine. The reservoir is full, with no bubbles, but executing the bleed procedure seems to have corrected it for now. I didn't think however that you had to disconnect the ps pump lines to change the belts, so who knows. The shop didn't reattach the heater plenum shroud, and the air filter was seated incorrectly, so it makes me wonder...
Now, though, with the whine gone, I've got a high-pitched, rpm dependent whistling noise eminating from the engine! It seems to occur after about 30 minutes of driving. It happened on the last two drives. I could hear it at idle while at a stop on the road, but couldn't get it to make the whistling noise while in the driveway. This I'm guessing may be the belt sensor (?).
I go through this cycle every few years...I finally relent and let someone work on one of my (out-of-warranty) cars, and then EVERY time the cars seem to come back with more issues than before I took them in!
I have the same experience. Thanks for the reminder, my DIY resolve is affirmed. Now if I could just find some time...
