964 Forum 1989-1994
clutch bleed
Old Mar 18, 2008 | 07:29 PM
Dwane's Avatar
Dwane
Default clutch bleed
I've been looking but could not find....Can anyone help?
thanks
Dwane
Old Mar 18, 2008 | 07:52 PM
MisterRisky's Avatar
MisterRisky
First, set things up like you were doing a brake bleed:
https://rennlist.com/forums/showthre...ghlight=clutch
and then reach up and bleed the clutch...
http://forums.pelicanparts.com/showthread.php?t=24208
Old Mar 18, 2008 | 08:09 PM
tbennett017's Avatar
tbennett017
+1 and +1
Old Mar 18, 2008 | 09:11 PM
Dwane's Avatar
Dwane
The 2nd thread is for a motorcycle...
Old Mar 18, 2008 | 11:22 PM
Indycam's Avatar
Indycam
Porsche car or bmw bike , same same ...
What do you want to know about the clutch bleed ?
Old Mar 19, 2008 | 02:01 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Ensure your fill the fluid reservoir ALL the way to the top, and then some as the fluid pickup is quite high in the reservoir. In other words, its quite easy to suck air even though there is still a fair amount of fluid in the reservoir.
Old Mar 19, 2008 | 09:16 AM
Dwane's Avatar
Dwane
Where is the bleeder valve?
Old Mar 19, 2008 | 09:53 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
The clutch bleed valve is on the end of the clutch slave cylinder. This is attached to bell housing on the top the transmission. You will need a 7mm wrench and a long hose to catch the old fluid. I'll see if I can find a picture for you.
EDIT: See #16 on this parts diagram
Old Mar 19, 2008 | 09:56 AM
DAVISRILEY's Avatar
DAVISRILEY
Bleeder valve is on top of the trans, a little forward of the engine/transmission flange, seems more on the drivers side. Easiest way I have found to do the bleed is on jack stands, drivers rear wheel off, and it is an all left handed job. I take the rubber cap off of the slave, break the bleeder free with a 7mm, hook line up, let it flush till clean, check fluid level, bleed again and tighten bleeder. I use a motive pressure bleeder, and it has worked well.
Old Mar 19, 2008 | 10:03 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
+1 on the use of the Motiv power bleeder.
Old Mar 19, 2008 | 02:20 PM
Dwane's Avatar
Dwane
Thanks Davis and Rob!
I have the bleeder as well.....
Old Mar 19, 2008 | 03:22 PM
Dwane's Avatar
Dwane
Job DONE!!!!!
thanks
Old Mar 19, 2008 | 03:38 PM
DAVISRILEY's Avatar
DAVISRILEY
How bad was the fluid? Just curious, as mine seems to be really black every time I flush, and I tend to do it at least 3 times a year. I am replacing master this week to attempt to fix a hard 1st engagement issue. Hope it feels better.
Old Mar 19, 2008 | 04:53 PM
loot87's Avatar
loot87
Is there a good thread on replacing the master and slave with the engine in?
Old Mar 19, 2008 | 05:00 PM
Dwane's Avatar
Dwane
It looked like crap Davis. This is the first time I've done it myself and not the last. The last time the car was in for service, I asked to bleed the brakes and clutch. I now know the job wasn't done right. The fluid started out being dirty yellow then green and FINALLY blue! I have not tried the car it's snowing here right now.
