Mmmm, Brake Rotors!
Agent Orange
I love it when I get brand new spanking parts (thanks to MS Road & Race). These rotors look so good, they should be in a museum! They are massive, the pictures don't do them justice. It's going to be a fun weekend in the garage
Wow, very nice!! What are the specs? How much?
Agent Orange
These are the two-piece 993TT rotors for the Big Red calipers. Pelican has them for $450-ish a piece.
Agent Orange
Hi Carl, the 965 and 993TT rotors have the same dimensions: 322x32. The advantage of the 993TT rotors is that they are 1) floating and 2) lighter because of the aluminum hat. PM me if you want to buy a set and I'll give you the scoop.
965 and 993tt do have the same 322x32 annulus dimensions but AFAIK they are not interhangeable due to a slightly different o/s.
We've been trying to get to the bottom of this for a while and need someone w/ 965 to accurately measure that rotor's o/s
Yeah I wish I had 2K laying around to change the uprights and everything involved. How about a 6mm thicker bracket or could a 6mm spacer worked with longer bolts? Same idea has a wheel spacer!!
other issues of the 964 steel upright w/ adaptor vs 993 aluminum w/o adaptor. not mentioned here, are weight and stiffness
