super-light carbon door panels
Thought I'd share... I finally got around to installing these after a year or so having a door panel with a speaker hole in it! Considering all the parts that are omitted from the stock door there is actually quite a weight savings with these things - the sheet of molded carbon is just a matter of grams! Plus, no ugly holes where the speakers used to be!
Ugly door shown first, then the improved versions!
Hey, Garrett-
Looks quite swell! A very clean design.
Carbon on the interior has me thinking big, ol' honkin' splinters in an accident.
Is that covered with a vinyl coat? Or is the carbon somehow chopped fiber?
Regardless, I guess it's not a problem at all seeing how everyone and his dog runs the stuff in the racing world -- but in my former aerospace world(s) those carbon splinters were some of the scariest things I'd ever come across (in the non-metal realm).
So what's the low down on it's construction?
-Lonnie
-Lonnie
Great looking. Does anyone know if you can retro-fit manual window regulators? Getting rid of two big DC motors, switches and wiring would save a few more pounds at modest cost.
My friend made these for me - mine were the prototypes. They are made up of 3 layers of 200 gsm carbon box weave cloth, vacuum consolidated to one atmosphere, and cooked in an oven for 4-5 hours. The resin used is aero marine grade epoxy, which has UV protection. They are not painted so they show the carbon texture and have a matte finish. The end result is 1mm thick (or thin, as Apple computer always says!), reinforced in the switch areas and the top round section to 2mm. They weigh around 300-400 grams!
Springer - I was thinking of removing those motors... This project was a weight reducer, but more importantly a hole-in-the-door sealer for me! It bothered me having those gaping holes in the doors!
(And if it's similar PW to what I've seen, it comes in at cured thickness of about 0.078" per ply. So, with your 3 plies... [engaging Jethro Bodine-capacity cipherin' brain] 0.234", or about 6mm... So, nope it ain't the same. Your's is about 1/6 thinner per ply. Very cool!
Good question! We debated screwing it in, but decided at this point to use double-sided tape. The panel is so light, and is held in firmly by wrapping the door at the top (we made it so it goes into the door frame along the entire window section), as well as the screws from the pull handle pin the mid-section, that the tape works great on the periphery and looks even cleaner versus using screws.
