RH Wheel Special!!!!!
RH NAP
18x8.5 ET52 and 18x10 ET54
$1,249.00 Set of 4 New wheels
$999.00 Set of 4.....2 new and 2 Test Fit This package is from our recent 964 photshoot/testfit. The two test fit wheels in this package are in like new condition, you can see some mounting marks from the tire being mounted to the wheel but you can't see these marks once the tire is mounted.
NOTE: When you purchase this set, it will require a 6mm spacer for the rear wheels for brake clearence. This is included in the price.
Hello Mathew,
I’m not trying to get **** you off here on the rennlist, however I have a question for you concerning your product line.
I have 6 RH 3.6 wheels, and I have had trouble with 3 of them.
I have the 18 inch 8 and 10’s.
The thing that has put me off the RH line, is that no one, and I have contacted GMP, the local Canadian RH distributor (who did not even know what an RH 3.6 wheel was) and even RH in Germany (who wrote back to contact you), will assist me by selling an outer or inner rim half.
I have 3 damaged RH wheels, but the only remedy through RH is just to toss it, and replace with new.
Matthew, can I purchase a RH rim half for repair on a damaged wheel? If not, why?
I’m frustrated with no support after purchase.
Watercooler. You might just want to get a set of new ones custom made out of stronger material. I know Jim Dorociak on here and Jeff Alton on Pelican are both in the know and could prob find a way to make some new ones.
Good luck.
Good luck.
watercoolers, I'm sorry for the run of bad luck with these those 3.6 wheels and that no one has been willing to help you, i've sent you a PM, and I have contacted Joe whose in charge of importing and repair service for all our RH wheels. We keep many parts in stock so that we can assist customers who bend their wheels. I can say that these wheels are pretty strong. They use the 40 bolt system and are TUV approved and I am a firm believe that no matter what wheel you have, if you hit something hard enough or run over something at a high enough speed every wheel can bend. Please send me your contact information via email and I will pass it on the Joe and I will follow up with him to make sure he has gotten back to you.
christer - nope that is just for the wheel -
basically the same as the real ones.
they are not light weight wheels - they look cool though (i had these on my 996, the porsche ones)
i like the look - just depends on what you are after
