Deleting the headlight level adjustment
hi, I'm about to delete the **** on the dashboard for adjusting the headlights , and replace it with a kill switch handle a la CUP. I saw that the switch is connected with two rubber hoses for the vaccum.
Question: Can I leave these un-attached or must there be a sealed loop for the vaccum in order not to disturb anything else?
Thomas
I may be wrong but I'd have thought you could plug the pipe and completely get rid of the one from the switch to the headlight.
Sorry I can't be more certain
Rob
Rob
As long as the hoses are still holding vacuum, you can just use the pipe. My preference would be trace back to where vacuum comes from engine and put a straight pipe there. (of course, that's what I'd like someone to do as I just ordered my headlights
There is a rubber "tee-piece" in the engine compartment behind the heater fan. Look for the three thin plastic pipes and disconnect the one that exits the engine compartment through the rear bulkhead then plug the tee-piece to prevent vacuum loss. The other two pipes are connected to engine components and easy to trace.
Regards
H
Regards
H
I'm in the same process. But I'm planning to place the kill switch between the rpm and oil gauges. There is a "invisible" hole there. Might this be an alternative ?
Thanks, now everything is crystal clear!
Regards
H
Regards
H
That should work, but I want the cup-look and I think the steering wheel may be an obstruction if you want to reach the handle in a hurry.
Today I have placed the kill switch handle in the hole were the front fog light **** used to be. But the there are to many bends for the cable so it doesn't move as freely as it should. The cup-position is better and more in a straight line.
Yesterday I ordered the ABS-kill swith from Porsche Motorsport and that will go into the other "hidden" hole between the clock and speedo meter. I will probably never use it but it looks cool and was only 33 USD![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
deoxford, you may not have it. it was an option. It will be the switch/**** in the first position inboard form ac vent at end of dash. You may just have a blank spot.
Regards
H
Regards
H
Super Duper Moderator
