Windscreen Washer - Weak Ejaculate Woes
So I'm keen to check them out.
But I can't for the life of me see where they are. I've removed the front cover, and I can *feel* the underside of the nozzle units, but I can't see to work. It's a tight squeeze under there, and at the limit of my finger length. Adrian's book doesn't cover this, so I could really use some tips. For a starter, where exactly are the check valves located?
Thanks!
There hiding under there sumwhere.
With the bonnet open i removed the plastic tray thing, and squeezed my hand into the n/s gap near the bonnet hing, messed about a little and found the pipes.
You can pull the washer jet out from the top as well, it only clips in.
The pipes are very thick plastic and are a pain. I changed most of the pipe for thin flexi stuff, took me 15mins or so.
Good thread despite the title
re windscreen washer wiper spray nozzle remove clean aim adjust intensive pump pipe clean reservoir tank.
Didn't realize the nozzles could be aimed so easily
And so easy to gently clip out from the top - helped remove lots of old polish residue too
