Where is the best place to put external temperature sensor
Here is my problem to solve
I bought a digital thermometer with display
Thermometer has a two-meter cable with external temperature sensor.
Where is the best place to put external temperature sensor.
I would like to put the sensor in the mirror
The location in the mirror is the factory solution but I have a problem because temperature sensor do not fit in the sleeve in the spring. The sensor is round 5mm x 40mm (0,2 x 1,6 inch)
Of course, I could cut the wires (then slip into the narrow spaces in the mirror housing) and then solder them. But I'm not sure thermometer then operate correctly.
Please help
Maciek
Please help
Maciek
