Broke a piece off plastic wheelwell liner
Where it mates with the little shield that mates with the front of the passenger side rocker panel sill piece. What should I use to glue it back together? Any ideas on glue or material?
LF
LF
Technical Guru
if you can use a 10mm socket and a phillips head screwdriver, you can accomplish the job in about 5 minutes once the car is on a jack stand and the wheel is off.
PS, the list price is about $200 and you should be able to get your dealer to give you the PCA discount or buy from an online dealer.
