Coupe 964
LOL
And your will to refrain from the mod bug...
Seriously, I think PPI is your best friend and the usual maintenance records would help eliminate most concerns. 964's are quite reliable, but still can be expensive if not well taken care of. Annual repairs/maintenance has been mentioned to be easily ~$2K, with some much higher.
Good luck.
Good luck.
I've just spend U$S 2.000 in my one month old 1993 C2, and I think maybe with another 2K it will be near perfect.
The car was in very good condition but as is usually the case, basic maintenance was neglected lately (shocks, tyres, rotors, oil, filters)
I also have a few minor oil leaks to solve.
Guess what? I love the car so much I can't stand driving my DD
1 Post
Just keep reminding yourself that the car is 14-15 years old and things are bound to go wrong. In reading this list for past 3 years, it seems like the most common faults are (in no particular order): oil leaks (most of 'em leak, I think) and electrical problems (switches, relays, etc.). Personally, over 3.5 years, I've had to replace the steering rack (~$800), a CV boot, an odometer gear ($25; easy DIY), a distributor belt ($10 and a DIY, although not easy), fan belts (cheap insurance), distributor caps ($100), rotors ($50), plugs ($75?) and had the valves adjusted (routine maintenance; ~$500), and the fan-belt warning sensor (easy DIY). Replaced a windshield also but that wasn't the fault of the car (~$900, covered by insurance). Two front tires (~$550; they wear faster than the rears). Front brake pads (normal maintenance). Clutch slave cylinder and replace transmission fluid (~$300? I forget exactly how much).
Burgled
In 4 years i have spent maybe $200 in repairs on broken parts and about $2500 in tires, oil changes and small mods. I cant complain at all about reliability. My car is about to turn 75K miles and I will be doing the valve adjustment /oil change, 2 year brake fluid change and general checkup over the christmas week off time.
Burgled
Man of Way Too Many Avatars
You need to count on at least 1500 per year in maint and extras. Every now and then you can get away with 500-800.
Just start a Porsche bank account and either throw 100 bucks in it every month or throw 50 cent per mile you drive it. You will either have saved for the standard or if you get away with less some for some extras.
$500 / year would be on the very low side and I doubt can be maintained for more than 3 years. If operating cost is a deciding factor, I would stick with the 3.2 and be equally content. The electronics and dual ignition employed in 964's can be quite costly to repair/service, while some parts for the 4WD system is just outrageously priced.
Super Guru
If you're budgeting $500 per year, I'd probably recommend you didn't buy a 964..........
