Price for a Clutch Replacement
I should be getting a quote from my mechanic today. Whats a good price (US or CDN) for this job? As well, I assume that I should only use Genuine Porsche Parts
All the best,
Jack
All the best,
Jack
I am having my clutch done along with other work but here is my price for just the clutch
$856.00 parts (clutch, bearings, guide tube, rear seal)
$1100.00 labor
$1100.00 labor
Originally Posted by buellrunner
Thanks Guys...
He should be calling me back today...Ill let you know what I get quoted...
Cheers,
Jack
Cheers,
Jack
It has been my experience that even though typical parts + labor for just the clutch may come in under $2k at an independent, the while-you-are-there fixes can easily ramp the bill up by $1k-$2k rather quickly.
Goodluck and save yourself some repeated labor down the road by taking care of the while-you-are-there fixes. In the long run, it will be cheaper to take the bigger hit now.
1 Post
ViperBob (on rennlist) sold me an RS lightweight flywheel and clutch kit for under $1400 when I did mine. If you go lightweight, I suggest the RS kit as opposed to aftermarket. Labor will depend on hourly rates, etc, but you can ballpark anywhere from $1000 to $1500 labor. Definitely think about taking care of all related components while you're in there. I even replaced the clutch slave cyinder and hose. And don't forget the rear main seal if it shows any signs of weeping.
