964 Forum 1989-1994
OBD1 Scantool Interface Group Buy (fully assembled)
Old 04-07-2008, 02:15 AM
  #76
RicardoD
RicardoD's Avatar
Well, I'm back after a long break away from Rennlist. I should have just bought more plugs from Mojorizing as I now can make my own plugs as well. So I re-invented the wheel. That's what killed my entire scantool project over the winter (and work demands, business travel, family etc).
I'm going to start shipping again next week so thank you to everyone who emailed me for your patience.
Old 04-07-2008, 10:20 PM
  #77
RicardoD
RicardoD's Avatar
Default 19 pin plug
Mojorizing,
Here is my 19 pin plug design. Its based upon round stock of Delrin. Its keyed and can only be inserted the proper way which is the most important thing.
It makes me appreciate all the work that you must have gone through to develop your plugs. Cause this turned out to be more challenging than I originally anticipated.
Old 04-07-2008, 11:30 PM
  #78
Gregg-K
Gregg-K's Avatar
Ricardo,
Nice job! What did you use for your pins ... they appear to be the correct ones formed from rolled sheet to give some compliance to suit the sockets they fit.
I machined pins from 1/4" dia brass bar for my plug, but it would be nice to have proper pins to match the socket.
... Gregg
Old 04-08-2008, 11:21 PM
  #79
RicardoD
RicardoD's Avatar
The pins are harting silver plated bullet nose pins. 2.5mm in diameter and work perfect. If you need a few let me know I can help.
Old 04-09-2008, 08:57 AM
  #80
Colin 90 C2
Colin 90 C2's Avatar
does this unit do system adaptation?
Old 04-09-2008, 10:29 AM
  #81
RicardoD
RicardoD's Avatar
I am not sure about the level of adaptation supported. There is an adaptation button on the software. I'm not a Scantool diagnostic expert as I focused on making a nice well packaged piece of hardware to support the free software. Perhaps other Rennlisters can chime in.
I know others have mentioned that they wanted the software to support idle/CO adaptation in future versions.
Old 04-09-2008, 10:59 AM
  #82
jimq
Burgled
jimq's Avatar
I have used it and didnt notice any difference. Just get in the car and drive and it will adapt on its own.
Old 04-13-2008, 11:27 PM
  #83
Ag02M5
Ag02M5's Avatar
Anyone think this will work with a turbo? Also has OBD1.
Cheers.
Old 04-14-2008, 11:42 AM
  #84
elbeee964
elbeee964's Avatar
Ricardo-
Your ScanTool package arrived Friday.
Worked slickly. (Especially AFTER I turned the ignition to the *2nd* detent. )
Packaged professionally w/ carrying case, CD, USB.
Nice plug you've made, there!
FWIW, I tried it on two laptops:
  • an 8-year old AMD-chip Compaq running W2k via the multi-pin connector.
  • a 4-month old Intel-chip Compaq running Vista via USB.
Both ran it sweetly.
(Prefer the responsiveness (perversely) of the older laptop. Go figure.)
Paid for itself right off the bat...
With ScanTool I discovered a problem whose symptom I'd always palmed off (since buying the car) on the car's computer system not playing well with a LWF.
-- Wrong.
ScanTool showed I had an intermittent Idle Switch when off throttle.
A quick undercar adjustment of the throttle cable -- and now ScanTool shows a solid Idle Switch ON at idle -- and I've got one sweeeeetly running car.
No more stop sign stalls, or rpm searching!
Thanks, again!
-Lonnie
Old 04-17-2008, 02:32 AM
  #85
RicardoD
RicardoD's Avatar
Ag02M5,
Someone tried hooking up to a '91 turbo and only got connections to the climate control, SRS airbag, and ABS. No connection to DME probably cause its a different system than the C2/C4. Here is the post about it:
https://rennlist.com/forums/showpost...&postcount=491
Old 04-17-2008, 10:46 AM
  #86
Ag02M5
Ag02M5's Avatar
Originally Posted by RicardoD
Ag02M5,
Thanks for the info.
Old 04-17-2008, 01:09 PM
  #87
Red rooster
Red rooster's Avatar
The 964 Turbo runs K Jetronic and does not have a DME ! Thats why there are no serial diagnostics for the motor.
Geoff
KS400200,the oldest 964 on Rennlist,unless you know differently !
Old 04-17-2008, 01:12 PM
  #88
Ag02M5
Ag02M5's Avatar
Geoff
Yep. I wonder if the Hammer provides any insight into the K-Jet system (granted a decent portion is mechanical)?
Old 04-25-2008, 02:51 AM
  #89
rob964.c4
rob964.c4's Avatar
I received the scantool yesterday.
and that all the way to the netherlands ,europe
Ricardo thanks it looks great
robert
Old 04-25-2008, 03:00 AM
  #90
Coleman
Coleman's Avatar
I have the Scantool- if somebody needs to borrow it, I'd be inclined to lend it out- I'm in California-
You can buy me a beer!
Coleman.
Quick Reply: OBD1 Scantool Interface Group Buy (fully assembled)
