Center console help w/ door lock switch
I pulled the cover for the 3 switches that have the emergency light, door lock, and the wing switch. When I pulled the cover all the wires can off of the door lock switch. Can someone take a look theirs and let me know where they go. There are four plugs and only 3 wires(Yellow,Brown,Blue). Thanks
brown = 1
blue = 4
Yellow = 6
unused = 3
Can you see the numbers on the switch? I pulled the above mapping from the wiring diagram so I don't have a picture to show.
blue = 4
Yellow = 6
unused = 3
Excuse my drawing, but is this correct. This is when you are looking at it from the back. In whatever combinations, I can't seen to get them to work. I have tried 2 buttons. When I touch two of the wires together the doors will lock.
Figured it out. The numbers are on the underside on the switch. Now this might be a dumber question, what is that switch suppose to do? I never used it before. When I finish installing the wires I did a test...the doors open and that's it...nothing else.
I have an issue with my central locking switch too, which started a "while" back.
If the doors are shut when I start the engine, the doors lock. The switch will not unlock them. I can just detect a little beep from somewhere while driving along, which only goes away if I unlock the doors via the twisty **** thingy on the door.
I suspect my central lock switch in the console is actually stuck in "on" position...
I've noticed that if the engine is off and no key in ignition, pressing the door lock button will lock the doors (found out whilst cleaning the console!). However, pressing the button again doesnt unlock the doors?!
Originally Posted by robh
Unless your alarm (if you have one) has an anti-hijack setting.
Some systems automatically lock the doors when the engine starts.
