Engine Drop
Engine Drop
I am having my engine dropped quite soon for a clutch change.
What else should i check while the engine is out, I know its a good idea to do the valve clearence, front cam chain seals, rocker cover gaskets and spark plugs.
Is there anything else i should consider ?
Dave
Dave
Kirk, I have seen engine insulation pads at AppBiz. I have no affiliation and no experience with them:
http://www.appbiz.com/index.php?manu...f9435d22ce9a30
An alternative might be to use an asphalt polymer like Dynamat (http://www.dynamat.com/) When I ordered my speaker covers from Parts Express I also picked up some generic Dynamat like sheets:
http://www.partsexpress.com/pe/showd...number=268-020
Originally Posted by Indycam
oil sender seals
Good thinking indy.
im doing the drop for Dave and when i dropped mine i re-sealed my oil sender.
I will add that to my list of jobs.
